Nightlife's insanity, ignorance and or quest for free energy. Please Help!
Started by nightlife, December 16, 2007, 06:57:55 AM
bocas
A charged capacitor has stored energy, a potential , a pressure, a static voltage.  When an inductor is connected across the capacitor it discharges, exchanging it's energy with the inductor.  This exchange is current.
hansvonlieven
G'day Nightlife and all,
Essentially your thinking is right on the money. You would do well to study Keely, especially when it comes to harmonics. Keely essentially held that there are three, and only three vibratory streams that make up the universe. These three vibratory streams meet in varying proportions (ie amplitude) and where they meet create the different manifestations of energy and matter as we know them.
For a primer on Keely's ideas have a look at my website http://keelytech.com it will give you much to think about and explore.
Hans von Lieven
nightlife
hansvonlieven, thank you for that information. I have read some things about Keely and I found that he may have been involved in Fords alleged design for the model T that is said to be able to run with out any fossil fuels if "Cow Magnets" were placed in certain notches that were said to be cut out in the bell housing of the first series of the Model T's. !909 I believe it was. The bell housing on those models were actually cast as part of the block. I did locate one in Nevada at a museum and I have yet to hear back from the manager there. I will send him a email to see what he found out. I am thinking that the one he has may have already been converted over by the ones who don?t want us to know about it.
Three men were said to have found out about it and they were said to have located one and then to have installed the magnets. They were said to have made it run on its own power and was said to have drove it to a meeting to show it to certain people. It was then said that they were on there way home and some was ran them off the road, killed them and took the motor. It was said that only two of the three were there and the third was sick and could not attend. It is know said that the third is in hiding.
That is about as much as I know about Keely but I will do some more research on him to find out about his therefore of only three vibrating wave streams. That would explain why some patents show three different coil?s in some of the TPU's devices.
nightlife
 We need someone to find out what frequency is captured and or created when a magnetic field is moved along a copper wire. Does any one already have the answer to that?
nightlife
 Here is some information I found and it looks like it will be hard to research his work since no one seems to have his papers because have have seemed to have disapeared. LOL, imagine that.
Who was John W. Keely?
John Keely was an independent researcher specializing in the properties of sound during the mid to late 1800's.
What did Keely discover?
He was purported to have discovered techniques based on incredibly sensitive vibratory mechanisms which would allow the use of the Aether for practical purposes.
What devices did he build?
1) a machine to split the water molecule for the instantaneous release of tremendous pressures
2) an engine which was reportedly driven by the flow of Aether into its components
3) designed and built a mineral disintegrator
4) an acoustic microscope capable of viewing into the molecular and atomic interstices of matter
5) a globe which could be made to rotate with no outside source of power as a demonstration of the Aetheric flows into matter
6) a belt device which enabled the operator to induce levitation or gravity in a test mass
What happened to his work?
On his death in 1898 of pneumonia, a Boston businessman purchased the bulk of equipment. On moving it to Boston, the man never successfully operated it which caused him to denounce Keely as a fraud. Many of Keelys papers were given to a Count Von Rosen of Scotland these papers were taken to Stockholm in 1912 and have been unaccounted for since. Scientific American dismantled the walls and floor of Keely's lab and found a large tank in the basement. Leading from the tank into the walls were a multitude of tubes which led them to proclaim fraud on the basis that Keely "must have used" compressed air to power his equipment.
Who continues the work?
At the present time and to the best of our knowledge, there are only two groups in the USA which actively research, correlate and investigate the work of John W. Keely
Dale Pond, Director Jerry W. Decker, Director Delta Spectrum Research
Vangard Sciences 1309 North Chestnut PO BOX 870716 Colorado Springs, CO Mesquite, TX 80905 (719) 473-8852 75187 (214) 324-8741
Journal Vibratory Physics $24 Yr. KeelyNet (214) 324-3501
One of the most astounding of his discoveries was the concept of the Neutral Centre. The Neutral Centre was at the heart of each structure in Nature ranging from the prion to the quark to the atom to the molecule to the mass aggregation.
Individually, the Neutral Centre acts as a drain for the Aether to pass presumably into the 4th dimension. When they gather or cluster, they each have a separate drain with another Master Neutral Centre formed from the combination of all the mass components. This is what is termed the "Center of Mass" in modern physics.
The velocity of the Aetheric flow is determined by the mode of operation by which the mass is currently ruled. The Neutral Centre can be thought of as an adjustable diaphragm which can control the amount of Aether which flows into the "drain" of the Neutral Centre.
The mode of operation can take any of three possible forms. Keely had broken these down into the Harmonic, the Enharmonic and the Dominant. In an attempt to make these easier to deal with, the terms used by the RFP theory are more expressive of the attributes of each mode.
For clarity, this paper will use the terminology incorporated in the RFP theory. Mode and force vector will be used interchangeably.
         RFP term              Keely term
         Pressor               Enharmonic
         Tractor                 Harmonic
        Dominant              Dominant
      Force Vector            Mode
The Pressor force vector (mode) accelerates and extends the range of molecular oscillation. When excited or brought into play, it causes molecular dissociation with a subsequent decrease in weight. The Pressor mode repels or pushes and is of the nature of centrifugal force in modern parlance.
The Tractor force vector reduces the range of molecular oscillation and will cause a general concentration of the mass components. This compaction of the particles of a mass will increase what is perceived as weight. The Tractor mode concentrates, pulls, attracts and is exemplified by the centripetal force in modern science.
The Dominant force vector can either stabilize a mass to prevent radioactive decay or bring on transmutation of one element to another. This mode completely rearranges all three modes (Tractor, Pressor and Dominant) in relation to each other. Transmutation is the most recognizable property of this mode.
A simple table of relationships is included to show the extent of these relationships :
      Pressor             Tractor              Dominant
    centrifugal         centripetal               still
   South Pole         North Pole          Bloch Wall
   CCW spin           CW spin              no spin
     proton               electron              neutron
     cold                     hot                 temperate
    positive               negative              neutral
    expand              condens             transmute
     push                   pull                   stabilize
As you can see, there are numerous verifications in Nature and science based on the trinary concept above the binary. We have found numerous correlations which are quite interesting.
These three modes of force must all three be present in any mass or mass aggregation.
The mass comprises 100% with all 3 being present in any combination of 3 separate percentages. For instance, if we assign (P) for Pressor, (T) for Tractor and (D) for Dominant, you might better understand the relationship :
(P=20%) + (T=60%) + (D=20%) = 100% the general proportions for much of the physical mass we are aware of THE TRACTOR RULES since T=60%
(P=60%) + (T=20%) + (D=20%) = 100% the general proportions for mass which is in a radiatory state, such as a light or heat source THE PRESSOR RULES since P=60%
(P=20%) + (T=20%) + (D=60%) = 100% the general proportions in effect when the mass is in the radioactive or transmutative state THE DOMINANT RULES since D=60%
  As you can see, if we can gain control of the trinary forces, we can adjust the relation of any of the vectors to achieve the effect we wish.
These can include levitation, compression by dissociation (if at a sufficiently high order of vibration, we could generate aneutronic energy), aggregation or materialization of matter, transmutation of existing matter and suspension of the aging process.
Since these are the Creative Forces to which Edgar Cayce refers, you can easily conceive of countless other applications and possibilities.
http://www.keelynet.com/keely/rfp1.txt
