I have a working shuman resonance circuit for sale
Started by magnetman777, December 16, 2007, 04:13:21 PM
AhuraMazda
Otto
Every little piece of information is helping to fill in the jigsaw. We don't know the full story yet. May be SM's batteries
ran out after 20 minutes but what was the p_out/p_in? This ship has a long way to go yet.
AM
Bruce_TPU
SM's batteries never ran dead after an hour!  ;)
The problem with running any of the TPU's for more than 2 or 3 hours was over heating caused by eddy currents.  Once the TPU was allowed to cool, it would once again run for 2 or 3 hours until once again the over heating caused by eddy currents would force it to have to be turned off.
I suggest that everyone reread the engineers report, as well as the battery comparison furnished by one of the engineers.
Never once did the batteries run dead.
Having said all of that, this circuit is cool because it is a receiver.  It allows you to receive and see the amplified sine wave from the shuman's.
@ Otto
The vibrating coil and magnet is an entire other experiment by MM.  And the vibration should be felt
on ANY coil, if you simply place a piece of plastic between the magnet and coil, when it reaches the resonant frequency of the coil.
Holiday Cheers,
Bruce
hansvonlieven
Quote from: btentzer on December 16, 2007, 10:14:02 PM
Well I asked, why the spikes, and can something be done with those spikes/kicks if you had enough of them fast send off?  I also asked what if he 'interrupted' the received signal from the Shuman's would there be a spike?  MM replied, "Yes, and it is much easier to 'interrupt' the signal at VLF, just a few transistors.  Interrupt it enough times per second, to produce those kicks and you have "perhaps" some usable power. MM agreed to experiment with this line of thought, also.
Holiday Cheers,   ;D
Bruce
Perhaps interrupt with radioactive rays like Hubbard and Stubblefield?
Hans von Lieven
turbo
gee this is neat...
i think i am also going for the bucks $$$$.
you are right the tpu is a fraud.
what a waste of time.
Grumpy
        -Frank Edwards
