Steven Mark`s TPU
Started by otto, December 18, 2007, 01:55:48 AM
Earl
Quote from: ronotte on January 17, 2008, 06:19:29 AM
@Earl,
Thanks, of course I did not put beads as the pulse XFM used are pot-cores. The funny thing is that only one of the absolutely equal other two does show said effect.
Roberto
Roberto,
try anyway, even with pot cores, to put a resistor on all three between gate and source to load down the gate impedance and transformer secondary.  Try various resistor values.
Obviously, exactly equal is not, there is a little difference somewhere.
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
ronotte
@Earl,
OK I did it: generally a 10KOhm is ok ...and I saw also that sometime they put a 22 Ohm in series with secondary...to lower the coil Q & limiting the max current (into the Mosfet's Gate @ said freq)?
Roberto
Earl
Quote from: ronotte on January 17, 2008, 06:42:56 AM
@Earl,
Roberto
Roberto,
In my opinion with transformer coupling, it is better NOT to put a series resistor between transformer and gate.  I would prefer 10k or other value from gate to source.
Does 3 times 10k from gate to source make all 3 FETs act the same way with no differences now ?
Regards, Earl
ronotte
Earl,
sorry it has been a typo: I wanted to write 'I will do it'  (when home). Now it's impossible
Roberto
wattsup
@Roberto
Good luck with your trials with both ECD and TPU. May be an interesting idea.
I found this circuit on ebay;
http://cgi.ebay.ca/8000V-High-Voltage-DC-Electronic-Electric-Generator_W0QQitemZ180205242697QQihZ008QQcategoryZ97200QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
If you can look at it and say if you think it is good to try. It is 8000vdc so it is well well below my current 100kvdc device. I still want to find one at around 1000 vdc but have not found anything yet.
Why I am waiting to build is simply because I want to see this thing working in my mind first and right now, I cannot see it. So I am going to make a few small devices like the TPU design just to see some effects before making the actual build.
