Steven Mark`s TPU
Started by otto, December 18, 2007, 01:55:48 AM
ronotte
Hi Guys,
here you will find what I mean for   ...TPU V10-7 POWER.....
http://www.youtube.com/watch?v=kzAkUFUb_y0
Enjoy
EM: your miniTesla is AMAZING...may be I'll find a way to use it to trigger my TPU!
Roberto
BEP
@ronotte,
Have you checked for inner rotation with a compass when the lamp is fluctuating?
Have you place the lamp inside the TPU during operation?
Thanks,
Bep
ronotte
Hi BEP,
always interesting hearing from you.
- No I don't see mag rotation or may be it's too high...
- Is there a rationale in putting the lamp inside the TPU?
TO ALL:
I DO CONFIRM THAT POWER FLUCTUATION DOES DEPEND STRICTLY ON THE SET OF FREQ IN USE: IT CAN DISAPPEAR COMPLETELY LEAVING THE LAMP NEAR IT'S MAX  BRIGHTNESS - STEADY
Grat news are maturing - stay tuned -
Roberto
Bruce_TPU
Hello Roberto,
Very good and interesting work.  I enjoyed the scope shots of your combined waves.  As I also enjoyed Jason's Video of combined waves, doubling, using a different method.
Watching this latest video, and your title of real power, the age old question comes up.
What is the output wattage, and what is the input wattage.  I will quantify a "working" TPU as where output is greater than input.  Until then, they are still interesting experiments to grow on, but not more than that.  This in no wise is to take away from great dedication and very hard work.
This is my standard for anyone claiming a working TPU from now on. Others may have their own.
Warm regards,  :)
Bruce
ronotte
@Bruce,
do you think I did not know?........If you just have a look to my previous post you will see that I already DID it.....so no way to warn me again....nevertheless I thought interesting for all to see it  (..not LEDs shininig..He He...).
Roberto
