Muller Dynamo
0 Members and 27 Guests are viewing this topic.
Hoppy
i_ron,
Excellent test which shows that the more capacitive reactance introduced, the less output power consumed in load. As reactance increases, Mr Lenz just gets weaker  because his food supply is diminishing. If we starve him of food, then we also starve the motor of power. He is if you will, a reflection of the motor. We can fool ourselves into thinking his actions have been surpressed by our intervention but there will always be a negative reaction as a result of our intervention which will re-balance the machine to maintain it running under unity.
Hoppy
konehead
I know what ron is getting at, that series cap will usually work like something that resticts current ant that is "it"
BUT
I dont see any helper magnets  like Fausto did in his video to adjust the inductance,
I dont see any coil shorting making high frequency osclaiitions like I did with series cap as high bypass filter,
I dont see any very high VARS produced first,  thorugh the resonate 90 degree shift, like Bolt says to do through lots of tuning first,
And i dont see a rotating magnet rotor that when it speeds up under loading of coils, it makes more and more watts from the speed up, regardless of elelctrical laws, like Romero does. (Romero doenst use seires cap anyways so good reason we dont see that ha)
All that can be seen is transformer, sereis cap, and lump resitive load.
and so why wouldnt that series cap to do no good at all but to restirct current?
Arthurs
Hi i_ron:
   Very good test, Very helpful to me.
   However: Although the capacitor value the greater the, Output power will be greater.
   But: the greater the value of capacitance, Rotor speed down the more.
   Only the capacitance values ​​as small as possible, Speed ​​will not decrease.
konehead
jsut was reviewing everthything past few posts and realized (I think) that it requeires two coils in SERIES, (like Arthrus circuit) to get what BOlt describes with the high VARS produced first...where the coils cause the current-lag "wihtin themselves?
IS this true anyone?
Thats why "it" can be done with sereis-adding bifilars since they are two coils within one?
Arent Ben's two facing coils in paralell?...maybe that is problem he is having.
Hoppy
Quote from: Arthurs on June 18, 2011, 02:19:08 PM
Hi i_ron:
Good observation Arthurs.
Hoppy
