Muller Dynamo
0 Members and 67 Guests are viewing this topic.
k4zep
Quote from: bolt on June 19, 2011, 03:58:08 AM
Try winding the coils in normal but back to back out of phase. Then try bifilar connections.   Even  multifilar with diode plugs on the ends. I don't know what works best and Romero want everyone to do their own research.
HV electrostatic charges can make another proxy without using cores. Im sure there are other ways too.
Hi Bolt,
Did you have these conversations with Romero in the past/pre motor?
Ben K4ZEP
plengo
Quote from: k4zep on June 19, 2011, 09:29:35 AM
Hi Bolt,
Whew, thank you for this post.  How many times did you say the above......a lot, I'm old and stubborn and just didn't think the bucking coils resonated would work, stopped messing yesterday, had lots to try but just repeating old test, didn't feel good, so , just thought about it. You kept repeating yourself again and again, finally listened....Hard to teach old dogs new tricks.
BUT.........IT WORKs.  Wheel runs faster with coils shorted, then in resonance, wheel runs even faster and does NOT slow down with load,  if tuned under load, even speeds up........  I'm going to have to rethink my whole idea about this!!!!!  IT simply unloads the system.
Basics:  Series coils 26.7 ohms series resistance (wow High!, expensive Litz wire!  Too small) Bucking, screwy waveform as they are not exactly the same.  29mH with magnet, 25mH w/o magnet, 6.5VAC PP at resonance (and thinking in the box, it should be zero)!  A lot to get a handle on here. Arrrrrrrrrrrrrrrr.
Going to rewind coils to get resistance down, etc.  Lots to do now....essentially starting over!
Photo below is output @ resonance, clean sine wave.  Onward and upward.
Ben K4ZEP
THANK YOU K4zep,
Its good to see that you indeed listen to Bolt and get to confirm his ideas. Would you be kind to draw a schematic of what you have done explaining (again) what you have done and how you precisely measured things? Others will, like you, understand better with pictures.
Do you mind Sharing with us what your profession was? Im supicious that you are an EE?!!!
Fausto.
k4zep
Quote from: plengo on June 19, 2011, 09:50:28 AM
THANK YOU K4zep,
Fausto.
Hi Fausto,
I will make a video with the schematics showing the effects, etc much later today.  I'm fighting some crud or something and just don't feel so hot right now.  But thinking up a storm as to where to go here!
As to my Pedigree.......ha, I'm a lifetime Electronic Technician, now retired, two years of Tec. School back in the late 60's, (remember the slide rule!?), Remember Dos 1.0?  First working in consumer electronics, then Medical R&D, then in industrial robotics for a Fortune 100 company (pay was outstanding), for all over 45 years.  I was blessed that my hobby was and has always  been electronics (built my first Crystal radio around 6 years of age), so I was paid to always have fun, be creative, etc. I was always the person who fixed something when no one else could, modified something that was unmodifiable, Taught many classes in electronics, etc. to many different pedigreed folk, it was my life. Have flown R/C airplanes for about 55 years, Ham radio operator for I think 56 years, Avid boater, Read constantly.  The Electronics profession paid the bills, put the kids through college and gave me a decent retirement. Unfortunately, it is a dyeing art me thinks with where digital is taking us. I swore when I retired, I would never work with a CAD system, never lay out another Multi layer PC board, etc. etc.   So what do I do when I retired, Putter in electronics but keep it simple.  I have always liked a challenge, to do the impossible, is what keeps me going at 68+.  This Muller/Romero device is one of those things.  So that's it........
Respectfully
Ben K4ZEP
Arthurs
Quote from: scratchrobot on June 19, 2011, 09:11:00 AM
I experimented with the dual coil in series and shorted them with an 1 ohm resistor, when second coil is in right place I get acceleration. Maybe other people who want to experiment can use this setup because it is very simple, just an old cd case and a pc fan.
http://www.youtube.com/watch?v=UJ7l3-0HIak
http://www.youtube.com/watch?v=FUIEQPMPp1A
Hi scratchrobot
Very good video.
You are 1 ohm resistor in series, do not use series capacitors?
2 generating coil is connected between the connection head and head? Head and tail still connected?
If you just adjust the first two to get space with the rotor coil rotor acceleration?
neptune
@Scratchrobot .I am sure a lot of people would like to replicate your work . But to achieve this , as always we need more info .Further to Arthurs questions . Please state number of magnets , their size , pole orientation . Are you using the fan motor to drive the rig . Coils . type and size of cores Litz or not , wire size , number of turns .If possible , resistance and inductance . How are the coils interconnected ? Do not underestimate the significance of what you have achieved . Speed up under load is the first massive step to overunity . If you fail to answer all of the above , then duplication becomes impossible .Thanks in advance .
