Muller Dynamo
0 Members and 25 Guests are viewing this topic.
chrisC
Quote from: romerouk on June 20, 2011, 08:20:25 PM
@wattsup
this is a picture from my next build.Even if it looks somehow like Muller it has nothing to do with that setup.I will post a video once it is completed but you will never know how it works even if it looks so simple.
Why do you think I am so stupid and spend lots of money to build more and more? Just for the show? well, this is a too expensive show without tickets, free, and I get nothing in return.
You have no ideea how expensive this is.
I am probably very stupid and have nothing to do with the money, just waste and keep people here entertained.
What do you suggest, should I stop the show?
Regards,
Romero
@Romero
Please continue to share if you deem fit. There are people who mostly because of ignorance, jealously, stupidity and mostly just because they have such high egos about themselves they cannot stand others taking center stage. Please ignore him so the rest of us can continue learning and maybe even contributing. Thank you for your time.
cheers
chrisC
4Tesla
@wattsup
Regards,
Romero
Nice work!  Look forward to seeing this new configuration!
wattsup
Quote from: romerouk on June 20, 2011, 07:51:10 PM
@wattsup
for long time I had a good impression about you and your posts and I tought you have good knowledge in understanding a real thing from the unreal.The fact that you cannot understand and succeed in making any OU device does not mean you are right.
If my device is a fake then prove it, if is not prove it again.
According to you we all should go to prison because we influence each other here, we replicate each other and so far nobody has achived any OU(actually some did), that means we all lie? What about Bedini? do you consider he is a liar? everyone here replicated some of his work.He was saying that Kromrey device can go up to 3.0 still nobody has reported that.
Well my friend, I can prove to you or anyone that I do have a working OU device, small but working, not the one everyone is trying to replicate now, that as I said milion times does not exist anymore. Is there any law that will force me or anyone to disclose our findings? I can prove it but I will not make public any of my work if I am forced to.We are all here doing what we do and we call it SHARING INFO nothing else.Most of us here found and discovered different things while experimenting and some info is kept and never released, should we call that hiding the truth?
I have hot published all my info to get something in return, nothing, how many time I said that.This was what I considered to be right and at the time I started to do first posts I had the intention to release all my findings, even if some of the things I did not understand how they worked.
It was enough to have a surprise visit and ruin everything.
What will you do after a special visit like that? I tell you, you will shit yourself and never touch anything.
I have 2 people here on the forum who knows all details about that and one of them saw the device working personally in my garden, we looked at it running for almost 3 hours.
People better keep quiet before someone will take this serious, we all know that the big guys are trying everything to stop all research towards any FE device.
Best regards,
Romero
@Romerouk
The proof was already posted on this thread but Mr. Plengo removed them. You can see the whole thing here about proof.
http://www.overunityresearch.com/index.php?topic=1003.msg14812#msg14812
If you know me, you will know I rarely give up until the reality is freed. I also do alot of bench work although because of this wheel, I have been doing less. I work with ether attraction now so for me, these mechanical wheels are play things. One day I will share it also but not till I know all I need to know. So I don't need any life lessons from anyone here. I am here for one reason only and that is to find the reality for those guys like @peterae that are with builds and others that are contemplating on spending some serious money on this.
So for me it is clearer then clear. Magic is only magic until you know how the trick was done.
So here are some easy specific questions that you can answer with a yes or no. I am not asking you to give up any secret that is supposed to be in the Romero wheel.
1) In your first video of the large unit, did you connect the battery terminals to the dc output rail of the generator coils? Yes or No?
2) In your second video where you remove the battery from the table top, you have two wires, a red and a black wire that are behind the unit going down inside the center opening of the table? Yes or No?
3) Referring to #2, do those two wires go to a battery under the table or to any other power supply? Yes or No
4) Do you agree that applying a battery to the dc output rails will bypass any other physics phenomena because the load will always be driven by the battery. The voltage may rise because the gen coils are producing some more output by maybe 3-4 volts. That is why you were reading 15.?? volts off the output rail. Yes or No?
5) Did you willingly create these videos to trick people into thinking the device was working in a way that it was not? Yes or No.
6) If #5 is no, why did you make those two videos and especially why did you do it in the way you did? Did you think that eventually we would not have found the tricks?
Your problem is simple. Instead of coming here and saying you made a wheel that does not work the way you want and you need help to find out what to do. I would have opened all avenues to help you. But you decided to play this big game.
Now if you want to come clean, this is the time and this is the place.
Just know that the link above cannot be erased by this moderator.
wattsup
PS: Just saw your photo of your new build. Expensive, don't worry I know what expensive is. I have done bigger then those. 12,000$ just for a custom built gear system. But hey, it's only money, right. lol
Now one more thing. A person that gets serious threats to stop what they are doing, and who is really scared of those threats, does not continue to make a new build. You see the problem we have with what you say and what you show is always contradictory. Just come clean and let's start from the beginning.
Magluvin
Hey Romero
Glad to see your still alive n kickin. ;]
Looks like a dual rotor setup. ;]
You have said all you need to Watts.. Not sure Watts uP with him on this. Not the norm.
Keep on keepin on.   ;]
Mags
plengo
Ok guys. Is every body happy now?
@wasup
You stated what you want. You even get a response from Romero. Let's move on. ANY MORE CRITICISM like this i will delete it.
Shall we?
@Romero,
Thank you man for your work. Keep it going and sharing please. I did learn a lot and never had a motor accelerating under load before.
Fausto.
