Muller Dynamo
0 Members and 215 Guests are viewing this topic.
bolt
Quote from: maw2432 on June 25, 2011, 06:51:55 PM
I guess this thread is too long now for my memory..... haha
Yes bifilar coils ... you can see 4 wires from each of coils romero posted way at the begining of the thread.
Very good observation! This makes perfect sense as i said before many times you must take every effort to cancel self induced current by changing the phase shift 90 degrees  using caps, or cancelling the phase using bifilar and or bucking coils either case inhibits current then there is no BEMF and no lugging then magnetic induction only creates a field Tensor to act on the ambient as a proxy.
e2matrix
Quote from: maw2432 on June 25, 2011, 07:22:07 PM
All,   Do you think a 47000uf/16volts capacitor would work OK?   I found them for a package of 4 for about 7 dollars on ebay.   The 25 volt 47000uf capacitors are very expensive.  About 20 dollars each or more.
Also,  I found it interesting that Romero could start is motor/generator just by hand using no battery.
Yep just put 2 ea. in series put the other 2 in series and put them together in parallel and you'll have your 47k uf @ 32 volt I believe.
bolt
Quote from: poynt99 on June 25, 2011, 05:16:45 PM
bolt,
With that sim you worked on, did it involve the use of a non-linear core for coupling the coil, bias magnet, and rotor magnets?
Or was it just linear air-core coupling?
Thanks,
.99
SIM can only do a normal inductor or transformer it knows nothing about ZPE or strange magnetic effects.
David70
looking at the wires coming from the coils I can see some of them with 3 wires some with 2 and looks that some have 4. Is it me not seeing right or..?
bolt
In any case you don't have to find the same value! Look around surplus stock you can pick up caps very cheap  any high value will work as a dump cap whatever you have to hand. Even old amplifiers have good size power smoothing  caps typically 63v and 10,000uf / 30,000uf is enough or put two in parallel.
A push start only has to get over 5v for the hall to start pulsing and the generator will pick up speed.
