Muller Dynamo
romerouk
Quote from: nul-points on May 08, 2011, 12:27:55 PM
hi all
please excuse if this is a DFQ**
(i've just looked thro' thread again and can't see this addressed previously, but with *my* eyesight you never know!)
in GL's diag, ok'd by Romero, the load (lamp) is shown as AFTER the DC-DC Converter
surely, it should be BEFORE the converter? (ie across the 47000uF buffer cap)
since the converter is, say, 80% efficient then 20% of all energy which enters it gets dissipated mostly as heat (ie. wasted)
if we put the load on the cap side then none of its energy gets wasted by the converter, am i right?
of course the converter is used to keep the voltage stable for the drive coils, so we have to accept the 20% (say) loss for their energy
but the convertor only NEEDS to stop any EXCESS energy going to the drive coils
so ALL additional excess is available to power any external load(s)
any comments? (or should i just start taking my meds again?)
great teamwork all !
np
(DFQ** = Damn Fool Question)
http://docsfreelunch.blogspot.com
I am using the bulb at dc regulator output only because before the regulator I have about 15 volts, but I could use 2 10w bulbs in series there.
I have tried adding a 50w bulb and everything stopped.The most I can take out is about 25w, after that even if I add just 2-3 watts more the system slows down a lot going to a stop.
I have done the testing and all coils/magnet arrangements with a 20w bulb loaded all the time.
It looks that the system is tuned for this load. The coils should have been larger a bit.Next build I will do better.
romerouk
Quote from: Aedini on May 08, 2011, 01:21:08 PM
Hi Romero:
    I really want to know the DC-DC converter which is what?
    I am very worried about hidden inside a battery.
    Very much hope that you can use facts to eliminate my doubts.
    If you have offended, please forgive, because so far no one has successfully copied.
http://www.maplin.co.uk/universal-3a-dc-power-supply-228639
do you really think that a battery that size will run the system for that time?
I understand you and all others having doubts but soon you will see more comming, not from me.
I have a friend who is about to finish a replication but bigger size, he started building about the same time I did. He is looking to get more than 100w out.I am curious too but confident that he will succeed.
eastcoastwilly
Quote from: bourne on May 08, 2011, 10:12:15 AM
Thanks Romerouk
@everyone
Am I correct in thinking Muller used magnetite powder at one point?
Lots of things to try out at some point :)
From Energetic forum from Dr. Peter Lindemann on making your own magnetite cores. Hope it helps.
Will
http://www.energeticforum.com/renewable-energy/7468-how-can-i-make-good-magnetic-sand-cores.html#post131820[/QUOTE]
EMdevices
RomeroUK,
thank you for your previous answers and new video.
One question I have is:  does the device operate with the stator magnets reversed?  Have you tried that in the past?
EM
romerouk
Thanks Romerouk
@everyone
Bill Muller stated that he was using magnetite powder. I have never tried but I do have about 1kg of magnetite powder and I will have to build a core and compare with ferrite.
Too much things to do, maybe some others will contribute and do some of this work.
