Muller Dynamo
0 Members and 139 Guests are viewing this topic.
e2matrix
Quote from: Dave45 on July 07, 2011, 02:10:16 PM
I hope Romero doesn't mind if I post this here, he say's to leave sw 1 open until max rpm is reached, notice that is what he does when running his rig.
thanks for posting that but is it possible to get a bigger or clearer version of that diagram?  Tnx
Rawbush
How does one hook up the scope to see current? I have 2 channel scope and would like to test this.
Peace
rawbush
e2matrix
Quote from: Rawbush on July 07, 2011, 11:22:38 PM
Peace
rawbush
I think most people try to use a 1 Ohm resistor to read across for current.  Put it in line with your circuit between power supply and load.
synchro1
http://www.youtube.com/user/Mopozco?blend=7&ob=5
A quote from Mopozco:
"The better inductance than single wind is always in place. Also it comes with more coil's capacitance".
What he's saying here is that if it works don't fix it.
Mopozco Has a transister and a reed switch that times the output short to coincide with the power coil back spike. Mopozco's Youtube point about multi strand upgrades is that more power equals more Lenz drag on the rotor, and his single strand coils already work this well.
I pointed out that Romero's second Hall transister perhaps worked the way this reed switch does over at Energeticforum.
darkwanderer
@lanenal
In the video the replicator has more voltage at the output than battery voltage...We can't say directly if it's working or not he only shows his device and the circuit diagram.
@mondrasek
Great work mondrasek. You are really close to solve the romero's device. But i have one question if you can answer it. İf you change the capacitor at the output how the rotor respond to it? Is it accelerating or slowing?
Thanks in advance.
