Muller Dynamo
0 Members and 154 Guests are viewing this topic.
Rawbush
So here are some pics of the modified rig. The drive coil set is separate and adjustable to the rotor, so that they can stay as close as I want and move stator plates out with out moving drive coils. Also the top stator plate coils can rotate advance/retard. I still need to hook up a drive circuit, I used 5 wire twisted for the drive coils so that I can tune impedance for rpm, each wire is about 25 ohms. Any way here is a few links, I will try to post to the main album.
Peace
rawbush
http://s259.photobucket.com/albums/hh315/rawbush/self%20runner%20projects/muller/
konehead
Hi Rawbush
very nice work - now you can see if the lower coil being a different distance from rotor magent as compared to upper coil will ignite some big resonate-power while coils are strung together in the cancelling/bucking mode and then you should have it (hopefully)
Rawbush
Thanks konehead  8)
I measured the two coil sets for documentation. I am using wire found in automotive relays, it measured all the same .005" but I think there are some differences. Next is to get the drive coil hooked up and running, but I am watching kids today so I can't hide in the garage all day. Will keep yall posted.
Peace
rawbush
Scorch
I may have missed a discussion about this in earlier replies but just wanted to add my observation:
When I look at the screen captures from Romero's video, it APPEARS that he has one hall sensor being activated by the tiny magnets in the edge of the rotor while the OTHER hall sensor is activated by the larger disk magnets.
If this is the case, then one driver coil is doing something completely different than the other.
On the Energic Forum, Mathew said: Dr Stifler, "For anything to be overunity, you must change the state of energy at least once". Most people relate that Electrical to Mechanical or vice versa. But you can change the state of your electricity as well and this becomes possible if the conversion doesn't cost to much. Forward time energy and reverse time energy are very real entities and allow one to follow the above rule with a near ease.
Did Romero change forward and reverse timing, or otherwise change the state of energy, by placing the sensors in these odd positions resulting in the driving coils behaving quite differently from each other?
From other Planet
@Scorch
Ya i had those thoughts too about the 2 driving circuits switched different ways.
Probably the driving circuit with hall sensor+ small extra magnets has weaker
force/acceleration (shorter pulse time) than the one with hall+ main rotor magnets.
Perhaps this is an important point to have these 2 different accelerations.
