Muller Dynamo
0 Members and 49 Guests are viewing this topic.
romerouk
Quote from: Magluvin on September 16, 2011, 01:15:55 PM
Hey Romero
Glad to see you around.  ;]
Have you tried sphere mags?  They seem to have an unusually powerfull field that seem to reach out far from the poles outward. Like it is beaming.  Just wondered if you have experienced this.
Also, have you tried alternating mag poles on the rotor N and S? This would not allow for a bias mag, UNLESS, it were spinning also.  ;]
Ya know, most manufactured motors/gens (alternators particularly) have cores that bring the back side of the coils into action, but we are not doing that here.  Not that manufactures are going for what were looking for, but many are very efficient.
Maybe 2 rotors/mags and the coil in between.    ;]
Ive also thought about rectangular cores. Like the ones that are used for IDE hard drive cables, that have a slot to slide the ribbon cable into.   Its simple enough. And it allows you to try flat sides outward,left and right, or up and down, to see if there are advantages. If the sides are L and R the rotor mag field has more area of attraction and maybe cutting more copper, and a short transition. And then vice verse, Up and Down, the core is denser, left to right, but a higher concentration at the edge of the core.
Just thoughts.  ;]
Thanks for the insights.. Your a good man.  And God has your back. Keep the faith.  ;]
Mags
Hi,
I have never tried sphere mags, I might try them too when I will have some spare time.
The new generator is exactly the way you describe it, 2 rotors/mags and the coil in between.
@Mariuscivic
Can you please add more bridges in parallel or make a bridge from normal diodes and use as many you can in parallel... Try first with one bridge and check the rpm then double the bridge and check again... You can also add capacitors for each side of the bridge.
Regards,
Romero
mariuscivic
Quote from: romerouk on September 16, 2011, 02:47:41 PM
@Mariuscivic
Regards,
Romero
Hi Romero!
I did try a bridge made with 3 diods in paralel and still nothing. Now i'll try  more. I'll also try with caps.
Thank you!
wattsup
Quote from: mariuscivic on September 16, 2011, 04:25:40 PM
Hi Romero!
Thank you!
Can you please consider the Alternate FWBR I show here.......
http://www.energeticforum.com/renewable-energy/7982-muller-generator-replication-romerouk-55.html#post156432
I don't know if this would be a good strategy also.
http://www.ebay.ca/itm/M3KV6-positive-high-voltage-DC-power-supply-multiplier-/270813579334?pt=LH_DefaultDomain_0&hash=item3f0dbf4846
So, instead of an FWBR, you use a voltage multiplier strategy similar to this...............
It takes in AC and dishes out much higher DC. Maybe a two stage or three stage could get the juice out of the coils fast enough to fall to null drag or near null drag.
wattsup
T-1000
In regards of motorogen acceleration, I just stumbled upon NASA research done 3 years ago:
http://www.youtube.com/watch?v=czXmazZ4obs
http://www.youtube.com/watch?v=WXKO8r-3xrw
http://www.youtube.com/watch?v=IQ9KLfusQPg
If applied to Muller Dynamo, it may have amazing results after tuning generator coils and see if driving coils could be replaced with HV gen coils after rotor spins up... :)
e2matrix
Quote from: T-1000 on September 18, 2011, 06:29:48 PM
Yep that's Thane Heins user 'Crankypants' here on OU.  IMO he knows his stuff and has some fascinating work.
