Muller Dynamo
0 Members and 31 Guests are viewing this topic.
konehead
Hi Khwartz
the circuit of mine you chose to modify doesnt pulse a coil like a  motor coil pulsing cirucit would do, it is a coil-shorting circuit, made for generator coils induced by magnets sweeping by the generator coil, the generator coil never disconnects.....
the FWBR in it, collects power into a cap "continuoulsy" and then when those mosfets trigger ON, it then shorts the coil leads together which increases the voltage feeding the cap.....
the circuit you chose to modify does not connect or disconnect the coil to a battery or power supply then, like a pulsed motor coil circuit would do...
konehead
Hi Khwartz
"Backing magnets" mean there are magnets stuck to the backside of the cores, like what Romero did...these magnets dont rotate lile the rotor magnets, they are on the backs of the cores of the coils, stationary...
I dont know if that formula you have  will work or not.
the formula for cap discharge converted to watts is:
FARAD value of capacitor being discharged  / 2
X
(volts in cap before discharge SQUARED minus the volts in cap after discharge SQUARED)
X
discharge events per second  = WATTS
mariuscivic
Hi Konehead
I don't remember the connections i made between the coils and FWBR.All i remember is that i tryed everything i know without any success.
Yesterday i was running my litlle rotor with a transistor.
Today i put back the mosfets as driver and the rotor went to the same 2230rpm but this time with 16.8mA.The ''directional canon-coil'' really makes a big diference.I think every one should try these type of coil. Also today i have made another coil bifilar but with the wires twisted just like the bedini coil type.With this one i was able to take out most of the bemf and put it back to the same battery.But still there were 70mA less to make it self run.
I have said before that i could smell ozone from coil's wires; I was surprised when i could smell it from the second bifilar bedini type coil
crazycut06
Hi all,
     I've watched again the romerouk muller motor, and guess what i found? i don't want to discourage everyone replicating this as i myself replicated this but no luck, [size=78%] but still finding ways, like others replicated this with their rig almost identical to romero's spec's were dissapointed with the results, here's the video please watch it carefully and give attention to the driving circuit to the right near the red screw driver, pls pause video to see clearly, near 10 sec.
http://www.youtube.com/watch?feature=player_detailpage&v=8KVU3ZM14rw
     1'st there is a negative wire (black) from the driving circuit going to the bridge rectifier beside it,(which woopyjump saw)
     2nd is the (red wire) to the right of the circuit soldered to the diode bridge's positive, connecting the positive rail of the generator output going to the battery (hiden under the multimeter),
     This explains why the voltage of the battery drops down as he connects the load (bulb) i was hoping that im wrong, not to give false accusations, but can someone explain this pls. for the sake of others trying to replicate that would cost their time and money....
God Bless Us All!
konehead
Hi Crazycut
I dont see any battery hidden under the multimeter but maybe there is one inside of it, and the DC to DC comvertor too so its all fake so why continue eh??
this list has been through already what you just discovered:
look at posts #703, #705. #707
