Muller Dynamo
konehead
Hi Skaarj
the sell very high voltage insulated magnet wire made for HV use and also you can insulate the layers with teflon pluminb tape too
when you hook coils in series, then each coil needs to make only "so much" high voltage but the overall votlage is very high then because they are in series.
crazycut06
Hi skaarj,
    What is your target input of your device? i don't think our romero muller replication cannot output such high voltages, thane hein's system is a bit different regarding coil construction...
Goodluck on your device! pls. post videos for us to see!
thevoice4you
Hi all,  ;) first post here, please to meet you all, this seems to be a good place to ask some opinions and a few questions. I made a resume on the following link about free energy not really being the main problem but storing it so take a look and your opinions are certainly appreciated.
http://www.view-tronics.com/mymindtwist/freeenergy/index.html
As I am in the process of building a system on the NEOGEN DYNAMO ! Question, how many watt is the DYNAMO able to produce at velocities between 500-1000 and 2000-3000 RPM or more ? That's it for now, another thing I just read somewhere that Bill his daughter died but is this true ? Best regard. Gery
truesearch
@thevoice4you:
Can you post photos of your build and the progress you are making? Also what difficulties and problems you have?
Best of luck!
truesearch
thevoice4you
Quote from: truesearch on April 17, 2012, 03:48:15 PM
@thevoice4you:
Best of luck!
truesearch
Well nothing for the moment as I am accumulating the info for a proposal that I have to do for the investors. The pilot project would be build a small container as it is going to be used to power a beach restaurant. http://www.claytonpower.com/products/lithium-ion-battery/ The container will house Compressor, tanks and a lithium battery power supply that will be used to make compressed air.   This power supply is charged by 2 wind generators and solar-panels.  Outside wind generators and solar-panels with micro inverters. energy.http://enecsys.com/products/installation_video_en.php http://vengerwind.com/v1turbine/
The idea is to use the MULLER DYNAMO only as the output power supply keeping it on a steady rpm with a regulated airstream depending on the load. Anyway will be posting the project when it progresses. thanks for your reply. ;)
