Muller Dynamo
tagor
Quote from: captainfletcher on November 05, 2013, 08:00:48 AM
PS English is not my native language, excuse me for the mistakes. (French)
personne n'a jamais reproduit le generateur , meme romeouk n'a pas reussit
a reproduire sa propre machine !!
Scorch
What haunts me is:
Zero Fossil Fuel appeared to make a substantial discovery but, then, has done little more to follow up on that.
He had a very nice system up and running, he discovered that it's possible to develop a resonance which resulted in a voltage spike, then he began building another unit.
But, to date, has not completed it, sold the original, then proceeded to work on other projects. . .
"Unlocking Muller Motor Secrets" By Zerro Fossil Fuel-
http://www.youtube.com/watch?v=yoXZHdiMCKE
And to quote from this video:
"Something quite extraordinary happened when I placed the 25mfd cap across the coil; it resonated and the voltage spiked when I did that."
And: "I am 99.9 percent certain . .  . to make it a self runner . . . it should be designed as a resonant electro-mechanical assembly".
And: "When this baby hits 88MPH; you're going to see some serious stuff."
That was video #285.
Which was followed by 8 more videos and the construction of another unit.
Why did he start building another unit when the existing unit appeared to do something special? I have no idea. . .
Then video #295 titled "The plot thickens over sparten1114, Muller motor update" which details some controversy regarding the rights to the invention.
http://www.youtube.com/watch?v=YRZ4PpN8Ht8
Two more videos followed detailing the beginings of building the new unit then . . . Nothing more than a few comments, here and there, about the Muller project as he continues to build OTHER things. . . .
So, yes, I, a mere bench jockey who knows very little about inductance, resonance, or sophisticated control systems; am still waiting and very haunted by this. . .
Hi everyone,
This topic even haunts me at night.
I read almost all the posts and this morning I am very tired.
In conclusion, I ask you to be honest before I started to build this machine:
Who among you have built and managed to make the generator RomeroUK / Muller work?
I'm retired electronics with few resources and the expenditure must be justified in my budget.
I have an oscilloscope and low voltage more power tools.
Thank you for your confidence.
captainfletcher
Hello,
Since I am interested in the free energy , the same scenario appears whenever an inventor is willing to make public his system.
Remember Steorn ! and many others who resigned just before !
I can not believe that it is every time a Fake , no.
These people get enormous pressure if it is not death.
Zero Fossil Fuel did not escape the rule. My knowledge of the English language is not sufficient to understand everything .
Our forums are monitored on LENR as Wikipedia . Additions for LENR is removed within a few hours after the posting .
I hate these people who act only for their own interests .
I am also surprised that eg topics related to MULLER are not deleted .
Then we can ask whether these " stakeholders " as " sparten1114 " really have the powers they claim ?
What do the English members of this video ?
For my part I bought today plywood cut and I intend to make a replica of the first machine RomeroUK and give here the results.
I'm 70 and I 'm not afraid of dying from a bullet, then whoever wants to scare me I expect . My family is assured....
Scorch
I removed the ugly, black, tape then used slightly less ugly general purpose adhesive and installed it in the bracket.
Quantamagnetics did mention that the reason they include all the extra hardware is because some people may want to experiment with this generator coil without actually mounting it to a Q2 or Q3 motor.
This way they can just use the bracket as a stand alone unit or mount it to something else.
I probably won't be using the extra corner bolts in favor of just using main mounting bolts in the same corners.
That is all for now and hope to get it mounted to the main assembly soon.
Scorch
More assembly headaches for me this week. . .
When I wound the toroid; I found very little specifications from the manufacturer with regards to actual coil dimensions or any notes pointing out possible clearance issues to beware of.
I just knew the specification called for 125 feet of 16AWG wire per side and the videos, and photos, appear to show a coil that takes up a little under 1/4 of the toroid per side.
So this is how I fabricated the jig and wound the coils.
But, when I attempted to mount this assembly to the main unit, I discovered that the 'feet' which are part of the mount actually hit the coils.
Argh!  :P
Please forgive me for not doing more engineering and checking exact fit of the toroid ring in an assembled mock up just to check exact position of these mounts. . .
And even in the manufacturer's video image; it does appear the coil is REALLY close, or even touching, this mount on at least one side.
I am not even sure if I could wind the coils any shorter.
They are already very close to the rotor and winding them shorter would make them thicker and reduce inside diameter.
So I made a compromise and instead of mounting these 'feet' per the original drawing, and images, I mounted them in the same position of the other brackets.
Whether or not my slightly longer, slightly less thick, coils might have any performance issues is unknown because this is an experimental device without any performance specifications so this is just . . . unknown. . .
Therefore I assume a slight difference in coil width will have negligible affect on performance. . . I hope.
Otherwise I will be winding these pain in the tail coils again. . .
That is all for now.
PS: Side note-
The main support bolts, at the bottom, only thread into the plastic nuts about 2-3 turns.
Wish these bolts were a little longer. . .
