Muller Dynamo
plengo
Quote from: romerouk on May 09, 2011, 07:01:46 PM
Hi all,
i see that many questions are about the resistance of the coil.
I don't have the generator at home but as I remember I maeasured it few day ago it was arround 1.7-2 ohms.I have removed one of the pair coils and replaced with a larger one and that has improved the system.
THANK YOU. Right here I stopped my replication direction and I am going to another direction. My current coil is 150mh and 156ohms while yours is 1.2mh and 2ohm. What a great difference.
Definitely the multi-strand coil reduces both values tremendously.
Fausto.
bolt
Quote from: REDCAR1957 on May 09, 2011, 07:40:20 PM
toranarod
how much are these rotors going to cost?
let me know when you find out
Kevin
Each disk in perspex or Acrylic going to  set you back about 50 euro/pounds/dollars so for 3 piece construction going to be around 150 plus all the other hardware, electronics and magnets looking at about 250/300 to build something similar. I am sure Romero has spent thousands in getting to this point.
I cant build this yet i got too much other stuff on the go with HHO etc but when i get around to it i will use 1HP 3 phase motor in RV mode, and bolt the rotor assembly direct to motor flange using all coils as  generator coils. Then i got precision bearing and mount already in place.
BTW i already seen a looped RV using this type of muller construction about 4 years ago over private skype call. I watched it for a couple of hours while it was being tuned and powering a few hundred watts of bulbs. I mentioned it on here many times but 99% didn’t believe such thing could exist.  Im pleased this is finally out in the open as for me it is not  a shock or surprise to see this OU device as i sure it is for most people here.
Check out Konehead he has been making these style motors for years. He met up with Muller many times before he died and has a lot of construction hints that will come in useful.
Oh wouldn’t you just love to go back thru the forum now to all those that said none of this is possible and tell em to stick it where the sun don't shine!! LOL
My Do It Energy
keep going, please don’t stop, the price of gas is going up another 6 cents as of midnight, the reason ? None, as usually.
“I have removed one of the pair coils and replaced with a larger one and that has improved the system.”
Did you also substitute the 6mm core with a larger one?
Mike
romerouk
Quote from: My Do It Energy on May 09, 2011, 08:21:24 PM
Mike
replaced the core with 10mm but just for one set of coils.
