Muller Dynamo
plengo
Quote from: skycollection on May 21, 2011, 01:01:44 AM
i am not an expert in electronics but i try to do the best i can...!
saludos
jorge
Hello skycollection. I am very glad you are around. You do great work.
Fausto.
keykhin
Here's a DC to DC converter I build. Maybe some of you will find it interesting. You may see a video about it here: http://www.youtube.com/watch?v=sqW2mbV3aDs and the schematic below
plengo
I have deleted probably 20 or more posts besides created (by mistake) 2 more thread so that all the TommyLReed rants and all that want to fill that thread are welcome.
http://www.overunity.com/index.php?topic=10781.0  and
http://www.overunity.com/index.php?topic=10783.0
please, again, I ask to focus on the topic "Muller Dynamo". Not rants, not "science is correct and OU is impossible". There are other threads for that.
After reading 120+ pages I am more than willing to keep deleting unnecessary posts.
Fausto.
infringer
Plengo = MOD of the year
Overunity.com
Great work plengo it is about time we got rid of the useless rhetorical crap that always takes away the driving force to push people to perspire. Inspiration is a much needed tool to exceed COP >1.
Without the question we have no drive if we start believing all these people who say this is foolish and impossible and we all do after it is constantly rammed down our throats we will never succeed. Believe no more let the question drive you.
"I think overunity is possible and everyone here does but, has romeroUK achieved overunity with his shared machine?"
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
konehead
Bill Muller also told me is that "all the amps is made on the first couple of layers of the coil against the core" whihc is pretty intersting...
and he went on to explain that when he winds his coils against his  blacksand cores, he does it while the special low-hysterisis amorphous  blacksand/epoxy mix he uses is still "wet" and so he squishes the firsl layer of wires into the blacksand, and gets more surface area this way and gets more amperage....
reason I am posting this is those sewing bobbins or whatever they are, that RomeroUK uses make it so you have a plastic-tube space between the ferrite core and the first layer of coil winds - so there must be a huge loss in amperage doing it like this.
I read here that one guy here building had that space machined down, but still there is no reason for anythign at all to be between the coil winds and the ferrite cores. Ferrite is electrically non-conductive, so best thign is tow wind right on top of it... put a small bit of super glue on the surface before winding too. (the super glue doesnt eat through the varnish so dont worry) also grind down a small groove (circumcision) near front of ferrite core to help prevent the coil winds from sliding off from the pull of attracive firing againt the rotor magnets to....also no reaosn for plastic between the coils and magnets either - drip some super-glue down the face of coil when through winding, let that dry (dont worry doesnt short anythign out) and then finally put coat of epoxy on surface of face of coil that faces towards the magnets....look for 1mm or 1.5mm airgap is good.
When you "pull back" the coil from tip of core as happens when you use those sewing bobbins you lose alot of power too since you want the coils to be right up ther next to the magnets....expecially when using coils as motor-coils the airgap between magnet sand coils is really important as being 1/2mm closer and you might have say 300rpm faster motor....so anyways I just dont like those sewing bobbins too much but if they work they work and probalby is best to totally replicate what Romero has done then imporve things after that...pretty soon it will not be argument if things are really overunity or if loopers are all elaborate fakes or not, but a freindly competions to make loopers the most effecint with most power outputs...
Also mentioned before that "solderable" litz wire is NO GOOD from motors and generators. it is really only "HOOK UP" wire and over time the very thin varnish will chaff from vibrations like you get in motors and generators and the coils will short and you will wonder what went wrong. USE "MOTOR RATED" wire - double coated, and the kind that regular soldering iron cannot penetrate the varnish coating.
