Muller Dynamo
MasterPlaster
Please can someone tell me: what would be the difference in the magnetic qualities if a coil is wound around a ferrite rod, clock wise versus anti-clockwise?
Tudi
Quote from: gotoluc on June 08, 2011, 11:14:38 AM
Hi everyone,
I remembered I had done a video back Dec 13, 2009 to demonstrate the effects of what a set of coils connected in reversed will do.
Link to video: http://www.youtube.com/watch?v=PTykNjDD0CM
It's kind of a long video, so maybe start it @ 3:30 to get to the experiment in question.
Thanks for sharing
Luc
sweet and awsome, so wanted to make that test. My internet is dead and stinks today. Any chance to write here some conclusions about your generator ? ( will take me ages to load the movies from youtube :( )
nul-points
Quote from: Tudi on June 08, 2011, 10:41:16 AM
:D so you did ask what i thought you wanted to ask xD
i don't think so, Tudi, but thanks for your reply anyway
i've often used paralleled diodes (you can see this in some of my own threads, over the past couple of years) to reduce volts drop
my question was - and still is - "is there any difference between using Romero's arrangement (which needs extra diodes) - and using only a diode bridge which ALREADY GIVES THE SAME VOLTS DROP (and doesn't need extra diodes)?
if Romero's arrangement does MORE than just reduce the volts drop, then we should investigate this effect
if there is NO difference, then we can just use a single bridge (eg. schottky) -ie.  to achieve the same drop
nul-points
Quote from: woopy on June 08, 2011, 11:00:50 AM
Hi all
Thank's to all for input
And especially to the coil inverting idea
I did invert the coil wiring of one of the  generative coils. (i flip the wiring of the top coil as per Penno)
and here are the trace
2 first pix = before the bridge  one without biasing magnet and second with biasing magnets. (very similar to Romero trace isn'it)
Laurent
thanks Laurent - that's confirmed what i posted in the 'MD for experimentalists' earlier about Romero's trace
...and saved me having to setup my coil test rig to reproduce the same trace i observed when testing my coil pair!
cordialement!
np
http://docsfreelunch.blogspot.com
gotoluc
Quote from: Tudi on June 08, 2011, 11:27:45 AM
Sorry Tudi that you have slow internet connection.
I did not end up building a generator on this principal. The video only visually demonstrates by using my hands, a powerful magnet and 2 coils connected in reverse will do.
After more tests I concluded that I could not generate as much energy as what the prime mover used. So I dropped the idea to build a generator on this principal alone. However, keep in mind that I did not experiment with ferrite cores and biasing magnets, so best to do the experiments to find the truth.
All the best to everyone and thanks for sharing your great research work.
Luc
