Muller Dynamo
mondrasek
Quote from: nul-points on July 18, 2011, 06:08:19 PM
at some point after making these tests, it would be good for you to try using biassing mags (& washers) on your stator cores, like Romero did
but what you're doing now is very interesting, please continue what you & neptune have been discussing
I tested backing mags early on and did note a HUGE increase in o/p V as well.  This was with my coils as close to the rotor mags as possible.
I then adjusted the coils fairly far from the rotor (matched the distance by scoping voltage on top and bottom coils in each pair and between the 3 pairs I have mounted so far).
With the coils very far from the rotor I could detect no changes when introducing backing magnets.
I have since adjusted my coils closer to the rotor two times.  After the first adjust closer the backing magnets still had no noticeable effect.  After the second adjust closer, I can again notice an o/p V increase when backing magnets are introduced.  You can also see how the o/p V wave form changes as the backing magnets are introduced.
I still have backing magnet testing in mind and just need to finish this intriguing antenna test.
M.
xenomorphlabs
Quote from: mondrasek on July 19, 2011, 06:39:11 PM
M.
In what ball park would your now extracted voltage and current be at what RPM (just out of curiosity) ?
mondrasek
Quote from: xenomorphlabs on July 19, 2011, 08:01:21 PM
You would have to specify at what load resistance you want that data (joke).
Here is the data I have at hand.
M.
xenomorphlabs
Thanks M.
That gives me an insight.
I am in my tests not yet satisfied with the voltage and current i get out of several individual test coils.
However i assume that the add-up of the differently phased signals
closer to the P2P values and hopefully the non-linear acceleration effect
of the biasing magnets on a full rig will contribute to higher extracted energy.
Therefore, even though i always avoid mechanical builds due to lack of tools and two left hands concerning this, i think i will put together a (probably crappy) bigger system with more o/p coils.
What would be good stator dimensions to go with a 20cm Rotor?
Would 30 cm stator plates be enough?
I think someone even made a nice laser-cutting bmp for the rotor earlier in this thread.
Guess i'll have to re-read it )
Do the shaft and the threaded rods have to be non-magnetic material?
Maybe it doesn't influence the magnets.
JuJu
296 pages in 2 months? uauuuu, quite impressive!! i have been out to much time..
sory, i gave up in the 23 page!!
is there any sucessful replication of romerouk muller device?
colective hug  8)
