Muller Dynamo
0 Members and 109 Guests are viewing this topic.
tysb3
there is from little bit different context, but maybe we are there too:
Now, one important thing that I will mention AGAIN, is that NEVER turn OFF prime mover while Generator have the Loads ON, NEVER!!
As also never turn Prime Mover ON while Generator have Loads connected and ON...
It needs to run for a bit, reaching normal working spec's before turning all loads ON!
Ufopolitics's Avatar Ufopolitics
DeepCut
I've been mostly off the forums for the past year, i recently got back into experimenting.
I only experiment with the AUL effect, as hoptoad says i don't think it can be OU but i know it can save energy, a simple thought experiment proves this.
Imagine a simple, standard generator, with it's high current coils. We know that motor/generator theory says that when a load is attached, this requires more work on the part of the generator to keep up the needed supply current, and therefore input power draw goes up.
Imagine the same generator with high-impedance coils that exhibit the AUL effect at or above a certain frequency. We attach our load, the rotor speed goes up, and the input current draw goes down.
I know very little theory or maths so i can only go on bench results.
I'm spending my money and time on this because i enjoy it and i think it can be made useful.
In the future i hope to have something proveably energy-saving and useful. Right now i only have devices that exhibit the effect, for testing.
Here is my pulse motor version :
https://www.youtube.com/watch?v=s8lI1VvM6Es&list=UUDz1_S1kOhi9nYZB0KV7znA&index=5
Here is a multi-magnet rotor version, driven by a motor :
https://www.youtube.com/watch?v=BLTcXeLsx3Q&list=UUDz1_S1kOhi9nYZB0KV7znA&index=4
Here is a simple transformer version :
https://www.youtube.com/watch?v=_XLXozK8csM&list=UUDz1_S1kOhi9nYZB0KV7znA&index=3
The next device is a so-called hybrid coil.
It combines okay current (0.5 amps) with high inductance, making a coil of 0.5mm wire of many turns.
The hybrid coil negates the downfall of seperate HV coils, because each additional HV coil introduces core-drag.
The next step after that device is to do a complete generator.
All the best,
DC.
synchro1
@Deepcut,
             I call the effect of the rotor speeding up accompanied by input drop "Lenz Propulsion". Here's the central fallacy of the Muller Dynamo. Multiple output coils divide and share rotor output, they don't multiply it. The same goes for the propulsion effect. When you add a second, identical, equally spaced high inductance output coil, both the output and the "Lenz Propulson" effect drop in half in each of the output coils. Thinik about what I'm saying. These findings came off my test bench. There's only one "X" amount of Lenz reversal effect for any given magnet rotor. This "X" factor has an upward limit that's constant in every system, regardless of how many, one or any number output coils are added.
DeepCut
Thanks synchro, you've obviously gone further with this than myself.
What are your thoughts on the effect within a transformer ?
DC.
synchro1
@DeepCut,
             The effect with the transformer is marvelous! I would imagine though, that you'll run into the same constant limitations I encountered with the multiple output coils if you try to increase the advantage.
