0 Members and 96 Guests are viewing this topic.
cub3
Quote from: henry14 on January 16, 2008, 11:35:21 PM
Hi guys,
I started checking this forum after I saw Al's video on youtube, and i've been following the progress of the replications this last week. Keep up the good work and good luck with your rep's!
I editted Al's video to slow motion and altered the zoom/contrast a bit, thought some people here might be interested to see.
http://www.dailymotion.com/video/x42px0_ocmpmm-slow_tech
Henry Absolutly brilliant,
one can see the stators shift and stall.
going for another look!!!
How can one save?
Regards Den
Charlie_V
@Lumen
Hey Lumen, I looked your video over.  Interesting idea but there's one part I couldn't grasp.  Now let me make sure I'm understanding your experiment.  You're using a coil based tachometer to produce a signal that your feeding into the scope.  You then use an optical tachometer to drive a transistor that shorts the coil/tach at a precise time, correct?
If I've got all that right then the part I'm not sure about is the signal coming from the coil/tach.  The signal you're showing on the scope is the change in magnetic flux from the stator, not the stator's acceleration/deceleration.  Speed information is a mathematical function that needs to be processed/calculated from the output frequency and amplitude of the signal - when processed it would look more like steps on your oscilloscope, not sine waves.  The signal from the coil/tach in the video is definitely raw unprocessed data.  You should get the same data by placing any small coil near the stator as it spins.  Shorting the coil as the signal starts to increase means your allowing current to flow as the north pole of the stator approaches the tachometer coil.  This will put a load on the stator magnet and cause it to slow down - taking energy from the system, not increasing it as what appears to happen when you get a latch.
The lower frequency oscillation you can see on the oscilloscope is most likely the rotation of the rotor.  Since the coil/tach is in close proximity to the rotor, it should see two changing magnetic fields.  A low frequency signal (rotor) mixed with a much higher frequency signal (stator) will produce the same modulation your scope sees.  What would be interesting to investigate is what the two signals are doing when you have a good latch like in Al's setup.  I bet they are some kind of harmonic (n), octave (2^n), or triple octave (3^n) of each other - maybe even a standing wave pattern.
If this is not a hoax, as it is appearing every day not to be, then I would say all you fellows working on this have stumbled upon the mechanism in which the universe uses to create energy.  I've theorized that energy is created when two fields, being spatially 90 degrees apart and of the same make up (i.e. both magnetic fields, or both electric fields, or etc), interact without any reactionary force.  I'm working on a project to prove this theory but my setup would not be something easily found in nature.  I've often wondered how the universe would do it, I think this motor (again if it's real) explains it quite nicely.  As a matter of fact, I would venture to say that the latch should occur when the counter-spinning stator's center point (the half way mark between north and south) is in alignment with the north or south pole of the rotor, and vice versa.  If this is the case, then you guys will need to bring the two other gear-spinning stators closer to the counter-spinning stator....  and make sure that the gear-spinners are facing south when the rotor magnet closest to the counter-spinning stator is facing north...  hehe it might improve your performance  ;)
Off to bed,
Charlie
henry14
Quote from: cub3 on January 17, 2008, 12:02:59 AM
Hi guys,
How can one save?
Regards Den
I uploaded for you here, Den :)  (if anyone wishes to rehost feel free)
http://rapidshare.com/files/84425022/ocmpmm.wmv.html
Also I have uploaded on Stage 6 which has a larger video size:
http://www.stage6.com/user/henry567/video/2086170/
cub3
Quote from: henry14 on January 17, 2008, 12:15:36 AM
Hi guys,
How can one save?
Regards Den
Thank's Henry,
1hr 5 min's to go. Dial up :-[ hope no phone calls  :'(
all the best Den
sterlinga
Doug continues to be delayed in his replica by some unfortunate developments that he's had to attend to.
Meanwhile, he has been making slow progress in his 1.5-scale replication.
I've posted some photos and such here:
http://peswiki.com/index.php/OS:MPMM:Replications:Douglas_K._Furr
http://freeenergynews.com and http://peswiki.com
"The best cutting-edge, clean energy news and directory service on the net."
