0 Members and 77 Guests are viewing this topic.
sveinutne
Quote from: vipond50 on January 19, 2008, 03:57:51 PM
To All Replicators and Group
Today after reconfiguration of the Stator magnets to a dual bearings I had a approximately. "one minute" self operation of the device and maintained a constant RPM once Stator Sync occurred. Note: What I mean by " Self Operation' is NO outside added input to the device. I added the second bearing to the stator due to instability to each arrangement. The instability induced friction and consequently drug down the rotor speed. Also with the device i am able at any time during spin up to latch any of the three Stators at any given time. In addition this allows me to have any combination of the stators running in synchronization.
My next step is to spend the necessary funds to Source totally all Non magnetic parts i.e. Bearings, Fasteners, Rotor center support shaft, etc. to construct a higher quality device.
I also understand that this is a variant of the original concept, but basic Engineering dictates that this is the next step.
Happy testing and may Your Rotors Rev up  ;D
Hi Bill,
This is good news.
I am thinking about using dual bearings on my stator too, to reduce friction.
From your video you got three stators in AGW lock. It is a very impressive achievement. If you replace the bearings on one more stator, it might run by itself. More that just one min. But one minute at constant speed is very good.
Svein
PolyMatrix
This maybe of interest concerning the whipmag effect
Valone further mentioned that Alexander Feigel is the first physicist to use ZPE to satisfy energy conservation. Feigel proved that virtual particles can be induced to travel in a preferred direction and transfer momentum, if they are in an electric field of at least 100 kV and a perpendicular magnetic field of 17 Tesla (10 kG), thus proving that the ZPF can cause motion of a dielectric fluid of 50 nm/sec (Feigel, A. 2004. ?Quantum Vacuum Contribution to the Momentum of Dielectric Media,? Physical Review Letters, Vol. 92, p. 020404).
Full article found at http://www.zpenergy.com/modules.php?name=News&file=print&sid=2598
Omnibus
Quote from: PolyMatrix on January 20, 2008, 02:55:12 AM
This is to be ignored outright. Trying to explain away violation of CoE with virtual particles is travesty of science. Explanation should be sought along the lines presented here: http://www.youtube.com/watch?v=tknwdltnB6s
PolyMatrix
If you care to work your way carfully through all Tom Valone has said you will find that he is not violating the CoE with this explanation as radiant energy dissipates back into ZPE.
Omnibus
Quote from: PolyMatrix on January 20, 2008, 03:10:39 AM
ZPE is a problem in Quantum Mechanics and not something to be celebrated. This isn't the place to discuss that, however.
