PolyMatrix
@ Yadaraf
Thanks for posting; would it be a good idea to put Al's original Youtube sound track alongside it for comparison?
Just speculating on waveforms and the soliton http://en.wikipedia.org/wiki/Soliton came to mind but can't figure how you could get that effect with magnetic waves. Still fairly certain that its to do with the elements of magnetic power, turning moment of inertia, so weight and radius are important, and a small vibration element in both or one of the rotor and/or stator.
The idea of a magnetic soliton would make the physicists and mathematicians very happy  ;D
As anybody who has played with magnets knows a stronger magnet when it gets close enough to a weaker magnet is attracted to it like it was steel.
Not sure if the mathematical model of magnets includes that datum.
dean_mcgowan
Quote from: Tinker on February 03, 2008, 03:07:21 AM
Hi Dean
"BTW if you read the thread where he claims this you will see that he states he has no intention of leaving it run unattended then almost immediately proceeds to leave it run overnight UNATTENDED !! HELOOOOOO !!"
But you left out the part about after 7+ hours he shut the device down and went to bed.
What insight would be gained by an unattended failure of the device beyond an obvious mechanical failure?
AL provided us with information about his findings. He has asked for nothing in return.
This information was presented for us to accept or reject, Do you have any evidence beyond supposition proving  subterfuge or deceit you would like to present?
Many here have seen value in AL's information and have spent time and treasure, and validated some of his information to be of value.
There are believers and sceptics in science, both have their place as they should. But no one knows for sure until the papers are published.
Tinker
Are you sure of that as I recall he shut it down when he woke up, before he had to go to work?
Cheers,
Dean
P.S If you know where it is in the thread can you please link, I tried finding it but ran out of steam ...
Tinker
Yes that is what he said.
I suspect he has a day job.
Tinker
dean_mcgowan
Quote from: Tinker on February 03, 2008, 04:04:05 AM
Tinker
Therefore you do agree with my point that his actions were contradictory?
Cheers,
Dean
Bruce_TPU
Morning All,
It is 3 AM in my neck of the woods, but I have posted two videos.  But I can not figure out why they have no sound.  They recorded with sound, and when I click the file on my computer, it opens in real player and has sound.  So why no sound on Youtube?
It is recorded with a web cam.  File type is .wmv
Thanks and I will read your help in the morning when I wake up and try to fix it.
http://www.youtube.com/watch?v=l2ycczuFEF8
Night all,
Bruce
