0 Members and 43 Guests are viewing this topic.
Yadaraf
Quote from: vipond50 on February 06, 2008, 02:19:06 PM
Quote from: Yadaraf on February 06, 2008, 12:24:56 PM
Quote from: Omnibus on February 06, 2008, 11:23:43 AM
@All,
I'd like to clarify something while waiting for my rotor to arrive (hopefully) tomorrow. The rigs I'm working now have the bearings in the rotor. However, it turned out that @alsetalokin's first video was done with a rig having the bearings in the base the shaft immovably attached to the rotor. Does anyone have more details about that? Drawings, dxf files? I know @alsetalokin appoved Jason's drawings with bearings in the rotor but still it's good to know what the actual construction in the video is. That's the only construction that worked, isn't it?
Omni,
Al's second video -- the one where he detaches the rotor and throws it away -- shows that the rotor bearing is part of the base (I believe).  It seemed similar to a good quality record player turntable that lifts off the motor spindle.  Correct me if I'm wrong.
Cheers,  :)
Yada..
@ Onmi
Al utilized an old Reel to Reel machine spool for the bearing support that he scrounged for some back alley.
Good luck on finding out what specific machine that was. In my Ver #2 Device U can relate the support concept.
I have been saying more or less all along that Al's the second version.... the one represented on the Video's was the only one that worked to my knowledge. For some reason it seem that the group has blinder on when relating to this. <grin>
Omni,
I've attached some pics of Vipond's rotor, which seems to best resemble Al's -- at least the rotor that Al trashed.  It's still not clear to me if Al was trashing the good rotor or a previous version.
Vipond, I hope you don't mind.
Cheers,  :)
Yada..
IMPORTANT NOTE:  The below picture is the second and newer of two rotor designs.
Please see:  http://www.overunity.com/index.php/topic,3871.msg75716.html#msg75716
Yadaraf
More of Viponds rotor.
Cheers,  :)
Yada..
Bruce_TPU
@ Fausto
That person was me.  And I have moved to using rubber bands to hold the stators.   ;D
Youtube guys think I am holding a drill in my unseen hand.  LOL  Jeesh I can't win.  No wonder Al got so bummed.
@ JFK
Al never said ceramic bearings.  Al said STAINLESS STEEL.  People assumed ceramic.  And he did not just mean the housing.
@ Omni
Al had gotten the device to work as we have, with the bearings in the rotor.  He went to the newer setup with the bearings in the base, for greater stability.  It was easier for Jason to design the drawing according to the original Al design.  As Bill mentioned, in the newer design, it was bearing salvaged from an old reel to reel.  Good luck finding that one.
Please try not to let some here confuse.  A lot of talk, making assumptive arguments sound like fact.
@ All
Has anyone seen this post by Harvey at Steorn:
http://urad.net/forums/WhiPMag/Bearing%20Permutations.xls
Cheers all,
Bruce
Yadaraf
Quote from: Bruce_TPU on February 06, 2008, 03:59:46 PM
@ Fausto
@ JFK
@ Omni
@ All
Cheers all,
Bruce
Bruce,
Thanks for clearing up the issue concerning Al's two rotors.  In Al's first video then, the red pully must be hiding the retaining nut.
Q:  Should I leave Vipond's pics up or are they confusing the issue?
Cheers,
Yada..
blue_energy
Quote from: Yadaraf on February 06, 2008, 03:27:31 PM
Quote from: JFK on February 06, 2008, 03:11:53 PM
Quote from: mikeytown2 on February 06, 2008, 03:07:03 PM
Pretty soon you guys are going to find that
4 + 8 + 15 + 16 + 23 + 42 = 108
Care to expound on your theory ?
Didn't think so. ;)
Allow me to explain ... before you get LOST ..
Scroll down to the "Numbers" section:
... http://en.wikipedia.org/wiki/Mythology_of_Lost
Cheers, :)
Yada..
And - when you multiply them together, they equal 7,418,880 - which, in binary, is: 111 0001 0011 0100 0000 0000.
Add the ones together as if they were base ten and you get: 7 - the universal lucky number.
...coincidence?
