0 Members and 50 Guests are viewing this topic.
Yadaraf
I've run a second spectral analysis using different software.  See Figure.
The tone at 174 Hz is unmistakable, and I've even verified it directly using a signal generator sweep from 170 to 178 Hz and studying the interference.  There is an observable "phase lock" at 174 Hz.
I'm now working on the second [higher] frequency, which might be complementary.  My hypothesis is that the Judson dampers affect the higher frequency, which might be tuned ideally to 852 Hz (see http://peswiki.com/index.php/Frequency and Google ).
I'm trying to contact the individual who produced the Peak Frequency video, so if anyone can help I'd be appreciative.
Comments welcome.
Cheers,   :)
Yada..
Bruce_TPU
@ Ken
Thank you.  That is good to know.  Someone trying to replicate this, uses non magnetic screws that build up eddy currents, etc and nothing works.
1 machine that works on the entire planet.  Precision with the smallest detail is going to be important.  IMHO  We will see.
@ All
Bearing guy has found Stewart-Warner bearings.  He has placed a call to them and left a voice mail.  I will touch base with him tomorrow and repost Mike's info, if you want to order some.   ;D ;D ;D
Cheers,
Bruce
evil-doer
you guys will want to see these videos..
this is the guy from ottawas generator
story here http://www.thestar.com/sciencetech/article/300042
vids (7 parts) start here
http://www.youtube.com/watch?v=ogLeKTlLy5E
MeggerMan
@Evil-doer,
Yes, he has proved nothing so far, no precise measurements of input power and output power as was mentioned in the correct thread:
http://www.overunity.com/index.php/topic,4047.75.html
His motor is consuming about 85 watts but there is no mention of generated power output power, so until he does then he will not get my attention.
@Bruce,
The 5x10x4mm ceramic bearings arrived today, they are stainless steel and teflon + ceramic balls, but the stainless steel may as well be soft iron because they love to stick to the magnets. :(
They seem fairly free running, one more so than the other, so I need to get more bearings to compare with.
If you are placing an order, find out the price per and put me down for 4 or more depending on price. PM me with the details.
Trying to figure a way of running these bearings in to loosen them up, I am thinking of running them for a couple of days off a small DC motor.
Rob
Yadaraf
RE Better [original] Al video in WMV format
I learned today that there is a better video of Al's device. It's supposed to be the original -- in WMV format.
WMV video of Al's device:
... http://www.overunity.org.uk/ocpm/alsvideo.wmv   8)
I've begun analyzing the WMV audio, and although close to the YouTube video there are subtle differences.  I found someone else who is analyzing the audio, and we are comparing [independent] observations.
Cheers,  :)
Yada..
