0 Members and 25 Guests are viewing this topic.
vipond50
@All
Today i worked up a relocatable arm to mount a Stator on so i could work the vectors in between the existing stator mounting holes. I did this to see if any phase 1 effects would present themselves. The arm has the radius the 13 (27.69 degrees intervals) stator mounting holes. It consist of two holes, one being the locator of the radius and the other being the stator mounting.
In case anyone is interested after prelimary location tests I have seen NO phase 1 effects, but more testing will be done.
Best Regards
Yadaraf
Quote from: AndreaGanora on February 08, 2008, 06:35:39 PM
Hi guys
Here is the link to the last video I?ve uploaded on my youtube channel
http://it.youtube.com/watch?v=TRS4_3F4lpc
It's a collection of different setup pics and some infos about my replication rig plus couple of video cuts about the rig spinning in AGW sinch and generating if not enything else , at list some interesting audio with many frequency changes that will maybe interest those of you that are into sound spectrum analisis , sadly i have no data about the rpms since I don't have jet a tachometer.
Good luck everybody with your projects
Ciao Andrea,
Fantastic video!  Great looking rig(s).  The tones you get after 05:48 are incredible.   :o  How close were the dogs?
You played country western music in the video.  Nice.  Is that popular in Italy?   8)
I like your use of rubber bands. I was considering mounting the stator to hard rubber, but rubber bands should do the same.
Keep up the excellent work.  If you get any sustained operation and record it, I'd like to analyze it.
Cheers,   :)
Yada..
Omnibus
@vipond50,
Sorry, I've missed that, what's "phase 1 effects"?
AndreaGanora
Quote from: vipond50 on February 08, 2008, 07:31:56 PM
@All
Best Regards
@vipond50
Way to go
Keep us informed on further tests .
Some pics of your adjustable stator's mounting brakets would be great
keep it up
Andrea
vipond50
Pic's of Relocatable Stator Arm. Please keep in mind there is nothing special in this(Very Crude). Looking for Phase 1 effects or anything other than spin down. ;D If any changes occur I will up grade this concept to a more stable design rotating of the rotor bearing shaft assembly mounting hub.
@ Omni
Phase 1 effects is after the hand spin up and the driver stator is in AGW rotation, but the secondary stators are still spinning in AG rotation as indicated in Al's Vid # 1
Phase 2 effects is after the secondary Stators are stopped and the device is spinning up using its own energy (if you will).
