RunningBare
Quote from: Craigy on January 11, 2008, 06:36:04 PM
Hi Grimer , well if its the real thing we still have a long way to go, but as the saying goes if you have enough chimps with pens they will eventually write a work of shakespeare. This might just be that work of shakespeare. I suspect Sean Mccarthy has all the patents regarding the testing of these things even if he hasn?t actually shown us a machine ....Regardless of the outcome its created a buzz that i have missed..
ps , anyone know of to way to stream webcam video , i have been looking at the vlc media player but have not downloaded yet. I would be nice if i could know how to do it from my web cam in the unlikely event something self sustains here LOL, when or if it happens i doubt i will be in the right frame of mind to set it up so thats why i am asking now...
I use windows media 9 encoder when I want a direct real time live stream, it does however require a lot of bandwidth for decent quality image, its quite powerful and free.
http://www.microsoft.com/windows/windowsmedia/forpros/encoder/default.mspx
Lakes
There is a site which makes it very easy to stream webcam video with little or no tech knowledge, one caveat is that the site in question can contain "adult" content, so over 18`s only, but it is free to join and I will set up a custom room that could be password protected if required to keep out the "normal" customers...
If you want to check it out the address is www.meetcam.com there are four webcam servers there, one of which is usually seldom used anyway.
Also includes voice and text chat.
EDIT: Its uses ActiveX (which is perfectly safe on this site) but becuase of this you have to Internet Explorer with XP or vista OS, it will not work with FireFox.
Thaelin
   Stephan also did a couple of links live here on OU from a place called www.ustream.tv. Seemed to work well and also had a chat area to go along with the video which had sound link also. He imbedded it into one of the messages so all you had to do was view the message and live you went. Worth a shot.
thaelin
iadcw
Hi guys
Haven't posted here in a long time. Thought I would update you on the following. Al explained he would start the OC-MPMM before he went to sleep and see if it was still running when he got up.
His words - a quote from steorn forum- - alsetalokin:
Shut down by stopping stator mag at about 09:43
RPM just before shutdown: Rotor 1257, Stator 5030
This was an over 7 hr run.
He stopped manually - Noone yet knows how long it will run. Pretty amazing stuff - history is being made here.
Bruce_TPU
Hello All,
Just a little update.  I picked up my bearings today.  They are very nice!   ;D  I also priced  two levels up, of precision bearings, and they will run just over $6.00 USD each.  Once our replication is up and kicking, this will be my first improvement to try.  The step after that will be air bearings.  Each type of bearing is rated for more RPM's, having less friction.  Less friction, less heating of the bearings, etc.  Who knows, but it is my plan.  I know the bearing's can be greatly improved and see how that effects over all performance.
I am still waiting on my magnets.  Hopefully tomorrow.  Machine shop found and parts to be ordered.  Exact materials called for.
I am thinking of a few other ideas also.  Laughable that some would attempt to patent an open source project.
I also am thinking, if the dampers are removed, it speeds up to??  becomes unstable, because of the mechanics.  A weak magnetic field at tremendous speed, with a properly wound coil can produce a lot of electricity.  Shrink it down, size it up. Figure out a way to remove the dampers and keep it stable.  What would the RPM's be?  7,500?  10,000?  15,000?  LOL
I do agree, a lot of fun ahead!!   ;D
Cheers,
Bruce
