0 Members and 80 Guests are viewing this topic.
FunkyJive
With so little time myself to build one of these things, I would like to ask if someone may be interested in building myself a suitable replication for a "consideration".
What's more, my electronics and scientific knowledge certainly doesn't make up for my lack of fabrication skills required for this device - though would be fun trying  ;D.
That said, I have a considerably simpler electronic counterpart of a motor in-mind (without any stall-points at-all), so perhaps an opportunity for further business if anyone were interested - strictly on the understanding that all findings and positive discoveries will remain public to this excellent forum?
All the best,
FunkyJive
"Invention has its value, but discovery is priceless"
"Faith from the wealth of negative speculation cannot deny faith from the sparks of promising experimentation"
"A quest of impossible odds is not driven by expectations of what is achievable, but by the certainty of what is not"
"It is not weak minds that perpetrate misconceptions, but strong minds heading in the wrong direction"
"Experimenters seek understanding from achievement, academics seek achievement from understanding, whilst sceptics would seek to deny them both"
"Once the world was flat lest we should fall off. Once man could not fly as he was much heavier than air. And so we arrive at another threshold"
BD Townsend
Bruce_TPU
@ Sean,
It may not matter, but I believe that with Al's setup, the stator magnets come to the "bottom" of the rotor magnets.  But I think this will make a difference for the latching effect, but if yours are adjustable, and it does not work, that is the first thing I would do, is drop your stators.
Great job as always,
Bruce
CLaNZeR
Quote from: btentzer on January 14, 2008, 03:59:35 PM
Hi Bruce
Think I may have to trawl through the 1000's of threads over at Steorn Forums to find this out.
Looking at the various pictures they all seem to show the Magnets level with the top of the rotor magnets, apart from this earlier rig that was photographed at a better angle to tell.
Looks like they are half way down the rotor magnets maybe?
Cheers
Sean.
http://www.overunity.org.uk
gdr
Hope this helps - quote from Al in Steorn forum in regards to someone else's rig:
"Just slight differences: the dampers on the real thing are mounted lower. It looks like everything is on the same plane in the model; in the real unit the plane of the rotor magnets skims the top edge of the plane of the stator magnets, and the damper plane skims the lower edge, if that makes sense."
BTW, great work... been intently lurking for quite some time  8)
-goofy
sterlinga
@ Jason,
Doug Furr asked me to see if I could get some clarification on what the damper things are for and how they mount.
My understanding is that they are to keep the thing from accellerating to destruction.
Any light you could shed on this would be appreciated.
Doug Furr had to go out of state today for an urgent meeting, so he'll probably be a day or two more before he's done with his replication.  I stopped in to see his progress last night.  He was machining the rotor on his CNC machine.  The base is done.  He showed me his bag of hundreds of magnets.
@ CLaNZer,
Would you mind providing me with your email address?  I understand you wish to keep it confidential, and I will honor that request.  Send to sterlingda {at} pureenergysystems.com.
Thanks
Sterling
http://freeenergynews.com and http://peswiki.com
"The best cutting-edge, clean energy news and directory service on the net."
