Working Magnetic Motor on you tube??
Started by Craigy, January 04, 2008, 04:11:39 PM
Bruce_TPU
Quote from: blue_energy on January 16, 2008, 01:24:36 PM
QuoteSince Alsetalokin mentioned that exact distance of the stator magnet to the rotor is quite important, I wonder how important slight differences between the individual rotor magnets strenghts are.
But how to determine the differences in the strength between the used rotor magnets?
And even more to the point: differences between the rated strengths and sizes of the magnets?  Most of the rigs I've read about seem to be using N42 magnets for both stators and rotor whereas, reportedly, Al used N35 magnets for his rotor mags.
You know, as cheap as the magnets are, it might not hurt to have an additional set of N35's to test with.  If someone could source it here in the U.S.
No reason I can see, to take a chance of missing it.  We try with the N42's and if after tuning, testing, etc, we can not replicate, we try the N35's.  Just my thought for the day.   ;)
This is so important, we can not leave any stone unturned.  IMHO
Cheers,
Bruce
robbie47
Quote from: lumen on January 16, 2008, 04:19:11 PM
I'm new at this so is this a good place to post a new video?
Sure, we're all curious.
lumen
I think the video may be too big (140meg), it reset my connection.
Omnibus
@All,
I want to report that the initial experiments are very promising. After the initial spin a definite acceleration is observed which so far still cannot be sustained as long as @alsetalonkin's but the effect is definitely there. I will restrain at this point from posting a video or quantitative results which I will present to you later.
Dyamios
Quote from: lumen on January 16, 2008, 04:27:53 PM
You might want to try uploading it to google video or youtube; both services will automatically recompress the videos.
