Working Magnetic Motor on you tube??
Started by Craigy, January 04, 2008, 04:11:39 PM
CLaNZeR
Quote from: btentzer on January 24, 2008, 08:54:08 PM
@ Clanzer
It will be interesting to see your wind down test results with the identical alloy that Al is using, compared to the aluminum.
Hi Bruce
I am cutting a standard base for this test and it is on the CNC machine as I type :)
Will then do a wind down with out the Dampners and 3 stators.
With normal stock alluminium bar Dampners and 3 stators
And with correct Dampners and 3 stators.
Cheers
Sean.
http://www.overunity.org.uk
RunningBare
Just a reminder of tachometer readings given by AL
Rotor: 1250 RPM
Stator 5000 RPM
The stroboscope is set to 4620 pulses per minute
The 3rd video appears to give a rotor speed of 1155 RPM, thats only 95 RPM difference from ALs tachometer reading of 1250
So taking this into account, I think we can safely say the tachometer readings and stroboscope are fairly consistant.
Omnibus
 This is not what I see in the first video. The effect kicks in around 1:35 into the video. After the effect shows itself he places the laser spot on the AGW stator and says it?s going 4200rpm but the readout isn?t seen to show that. Then he again places the laser spot on the AGW stator the readout now showing first 1248rpm then some erratic number 1.8 or something, then  1248rpm again, again an erratic reading :1 P and finally 2860rpm followed by gibberish once again and 1248rpm the third time. In words he?s saying ?the little magnet is going 4200rpm? but that never shows on the readout. He mentions interaction of the fluorescent light and 1700rpm referring to the AGW magnet which again isn?t seen on the readout.
After stopping the two stators measuring the AGW stator he indeed says ?almost 5000rpm? but the tachometer measuring the AGW stator reads 4131rpm.
Not only the measurement seen in the video is messy but at no point measurement of the rotor rpm seems to occur.
CLaNZeR
Well as close as I can get to the original Rig for the Wind Down tests.
Got to shoot out now, but will fire her up later and post the results.
Cheers
Sean.
