The First TPU
Started by EMdevices, January 04, 2008, 05:41:48 PM
Chad
@Tosky
well "Maybe" if the device is feeding from the earths magnetic field and electrons are traveling around the collector coils in the "correct" direction for the device to operate, so when the device is flipped over the electrons will be traveling in the opposite direction to draw the magnetic field... so the TPU will begin to stall, also if you notice in the video when he flips the device over the magnet he has attached lets say he has it oreientated with the earths magnetic field.. so this also is on the opposite side to wich it started reversisng the poles in relation to the earths magnetic field.
turbo
Hey EM :)
thanks 4 the writeup..
are you going to analyse the other vid's too? :)
M.
tosky
@Chad
The tornados always screw to the earth not to the sky. It is because gravity. If a vortex is needed and happening in the TPU then electron as elementary particle should also screw to the earth.  But I don't know whether tornado rotates only clockwise or both direction. If only clockwise there may be some physics related to the TPU.
wattsup
@EM
Good work on the transcript.
Notice in the presentation, he put the magnet on first. Then he fiddle around on the meter pushing buttons. Why did he spend so much time on pushing buttons on the meter. This should have been set to DC volts before since he new he was doing the demo and he must have practiced the demo a few times before video tapping it. This gave the time for the TPU to increase in voltage before the meter was on and showed 61.5 volts. Also by doing this, we could not see any starting voltage readout, like maybe 12 volts or 9 volts.
Come to think of it, he always starts the units before he looks at the voltage. never see the voltage with the unit off. I SM leaves nothing to chance, there is a reason for this.
1) Notice when he says the voltage is "down now to 13 volts 12 volts it stops producing electricity". We should look at this sequence VERY carefully and count the time it took for the voltage to drop. I tried looking at the meter readout but the video is again the craps. He had enough time to say 13 - 12 volts. It can give the impression that the voltage never dropped below this level since he said at that point it stops producing.
2) 61.5 volts - 25 watts = 0.406504065040650..... amps.
A little less then half an amp.
3) Dead Give Away when he says....
"it doesn't contain any batteries capable of generating the amount of electricity that you're going to be witnessing here..". This is another way of saying that there are batteries to run the circuit, but never enough to run the whole output you are witnessing.
4) In general the first TPU demo was not long enough to prove any OU.
5) Again. Circuit is inside the ring. Always a constant.
6) Son of a gun - the magnet position...............
You can see near the toroid there are two bailing wires coming out in front of the toroid like a left and right magnet stand on which he put the magnet. The magnet is actually about 1 inch away from the toroid. I have prepared some drawings below to explain what this is being used for physically.
One magnet field is "probably" going around a top bailing wire and the other field the bottom bailing wire. Both wires are around the outer rings and this is why he is using a silicone type of adhesive to keep the wire in place. I don't know if the discs are metal or not but would guess not.
I have tried many tests with bailing wire with a magnet and or a coil and the field goes all the way around.
Grumpy
        -Frank Edwards
