The Moray device
Started by allcanadian, January 05, 2008, 02:52:09 PM
Pephyon
Audio Amplifiers are Vacuum "Tube" Amplifiers, they do not incorporate Solids-State signal processing or have the same properties like this kind of triode found in http://jnaudin.free.fr/html/vta.htm
Pephyon
Quote from: allcanadian on January 05, 2008, 02:52:09 PM
Here are some aspects of the moray device that are usually not considered, in the picture below(upper left corner) is a basic crystal radio
compare with this quote
Quote from: hartiberlin on July 28, 2006, 11:17:45 PM
It was also radioactive and worked as a nice
"passive amplifier" for radiowaves, when he tried this
as an diode in his earlier radio receiver experiments.
Pephyon
Quote from: Prophmaji on September 11, 2007, 12:26:00 PM
my family used to sell CB's or Citizen's Band two way radios.
When electrica storms used to occur, we would disconnect the antennas from the radios.
When the lighting would strike,the antenna ends would fire a spark from the tip to the ground on the antenna lead.
When this happened, the cable would both twist and move in a specific direction..of course. The combination of all three is very, very, very, very telling, when it comes to vortex work. Or understanding the base nature of a 'interference' of two waves creating a resultant vector that 'infringes' upon our dimensional vector, thus creating atomic structures at the nexal point of the waves..thus describing reality and all the issues we have in understanding it. The atomic or vibratory quanta interference meeting point of the fields and the resultant vectoral equvalent is the essence of atomic structure. Thus the vortex action. Thus the fact that heat can be substituted for time in formulas that are true to the real nature of the universe. The wavefrom's meeting point describes the two reflections of energy off two 'surfaces' Inside and outside. Nucleus and electron shell. All simple hamonics from the angular components that describe the vortexural meeting point of the planar 2-d waves. Of course, once again, the overall vectoral resultant describing the given atomic structure, as it protrudes in this 'dimension', that we like to call 'reality'.
This simple point tells one, flat out, that frequential resonant energy manipulation is the key to opening all doors in energy manipulation.
it's not the only key, it is merely the easiest, and most prevelant and prolific, in terms of effective results.
A simple point that illustrates this. Silicon, or glass, when solid, is an excellent insulator and excellent dielectric. As a heated liquid, it is an excellent....conductor. This is true for most materials, when fluid.
Check the thread "Build a Moray-like device".
