Gyroscopic effect
Started by angryScientist, January 08, 2008, 02:18:07 AM
libra_spirit
Quote from: sparks on January 17, 2008, 04:28:42 PM
libra_spirit
"An electric arc shooting into a magnet will allways strike the edge of one pole it will never hit the end of the magnet. A radio wave will pass through without being bent at all."
   This is interesting because the transverse em wave acts as all potential emf yet it radiates.  So it's radiation must be driven by a force that is  neither electrical or magnetic or gravitational.  It is not a rolling magnetic electrical construct  which I was taught it to be.  I postulate that the potential energy is radiated through the Universe due to anti-gravity or what I call dispersion force.
         The crt is just an electron gun and the electrons are just dipolar electro-magnetic constructs.  So the electrical potential across the tube  causes the electron kinetic response, the ray of electrons is created by magnetic concentration of the emitted electrons and the ray is swept up and down back and forth via electric fields of the plates in the tube, while the amount of electrons emitted is controlled by the grid potential causing intensity changes in the ray.  This ray strikes a coating of matter that changes the electron kinetic energy into light emission.  And the light energy radiates into the room because it is dispersed via electromagnetic wave propogation which is dispersion force at work again.  How does the emitter of the tube feel the potential of the screen.  I believe this is called a positive charge.  I believe a positive charge arises from the second force of the Universe called gravity.  The protons positive charge arises from a fundamental force to concentrate or collect.  Energy is dictated by the relation of these two forces.  Matter a state of equilibrium of these two forces.
I would suggest a thrid force, one of tempic field or spin momentum. The only force being propagated by the light photons that move straight and are not bent by the magnetic fields. As the electron shells of atoms absorb these photons they have a reaction to increase or decrease their spin and thus their voltage.
This is the force missing in the universe [dark matter] and is contained within spin, its propagation is via light energy.
Dave L
sparks
        This force then would be a force to stay as is which would give rise to inertia.  This force always needed to be overcome before potential energy converts to kinetic energy.  The Earth then is a large dipole converting potential energy from the sun into spin.  The orbit distance from the sun predicated by this conversion.  The orbit velocity predicated by the interaction of gravity, and dispersion.
    I have stated before that Mark's tpu is a model of the Earth or a large electron.
I believe the Earth is bombarded with emwaves of large magnitude and wavelength constantly.  The Earth's magnetosphere interacting with these waves and converting the energy of these waves into a vortex electrical current inside the core of the Earth.  This vortex energy is coupled to the liquid core of the Earth and gives rise to the Earth's spin and magnetosphere construct.  I believe Mark's tpu works the same way.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
angryScientist
Here are some more visuals of the basics. Never hurts to keep the basics in mind.
Above; Electron and proton starting with the same direction of travel. The two are deflected in an opposite sense because of their charges.
Proton = red, Electron = blue, Magnetic flux = green
Below; Electron and proton starting with opposite directions of travel. This time the two are deflected in a similar sense because they travel in opposite directions. Obviously their periods of rotation differ because one is ~1800 times more massive.
Edit: Oops... I meant to put an image tag not a url.
sparks
@angry scientist
   I believe what you depicted was proton travel due to magnetic alignment of the neucleus with a changing magnetic field?
Think Legacy
Spread the Love
angryScientist
@sparks
Actually I was trying to depict a free electron and a free proton moving through a steady magnetic field and the force exerted on them that tends to change their direction of travel. It's the same kind of diagram that you could find in a physics text book. That's what I was trying to do any way. ;)
I guess I have never been too spectacular at explaining myself, at least that's what the judge would have said. ???  JUST KIDDING.
