The position of the moon affects magnet motors
Started by cheesefighter, January 08, 2008, 06:57:46 AM
hansvonlieven
We know about the diurnal effect, but pardon the question, how does the moon get into this??
Hans von Lieven
Ren
Casman, have you taken into account that your battery will fluctuate in voltage due to temperature alone?
shruggedatlas
Quote from: cheesefighter on January 08, 2008, 06:57:46 AM
I have been experimenting with repulsion magnet engines for awhile and have observed that at midnight they lapse in  power. Has anyone noticed this?
What does midnight have to do with the moon's position?  Did you perhaps mean the magnets lapse in power when the moon is more visible?  If so, how?  The magnets do not have optical sensors, or do they?
Prophmaji
Pulled from another thread:
The vortextral balancing act of what an atomic structure is, ie, Oscillating 2-D planar field interactions of 'vortex in-vortex out'..to create the 3-D universe of the given resultant vectors and all the components of this 'world'.....this balanced dual vortex, in equilibrium, requires brute force and/or resonance to break it (gyroscopic equilibrium), but localized attempts at bleeding energy off the 2-d field interaction balancing act, may not be all that fruitful, unless this vortex consideration is understood and taken into account. The vortexes in balance are fed from outside their localized areas, as they exist due to Oscillating 2-D planar field interaction. Which is why it is difficult to get them off balance and why the energy levels observed are so high (how much is released, or how much required to break) when they are cracked into being off balance.
If one fully analyzes all known phenomena, of any kind -real or suspected-  they all fit the Oscillating 2-D planar field model. Up to and including all aspects of multi-dimensionality and all observed psychic phenomena. Eg, the unidirectional characteristic of time, in this 'dimension', due to only having access to the outer spin component, for the most part. If you analyze that for a second, you can see how probability exists (additive-interactive vectoral possibilities) , but the past is determined and stable.
Aether, in other words.
Prophmaji
