Can someone show me a design that has worked?
Started by Roen Hayden, January 14, 2008, 03:25:46 PM
b0rg13
if you want to get out of the rat race,you have to let go of the cheese.
BEP
Quote from: hansvonlieven on January 18, 2008, 02:51:02 AM
Don't forget on U-tube even Godzilla is real.
??? Don't even start that idea. After all, there are far more videos of him - grainy, sound track out of sync, a mysterious hum in the background, almost invisible strings hanging from outside camera view, blow dryers in the corner......
A common thread! OU researchers are all out-of-work Godzilla investigators.
I just avoid him. There have been some service trips I've refused to go on. The boss would never guess it is because of Godzilla.
RunningBare
Quote from: PolyMatrix on January 18, 2008, 05:09:32 AM
http://video.google.com/videoplay?docid=-5738531568036565057&q=zero+point+energy&total=921&start=0&num=10&so=0&type=search&plindex=0
I have lost count of the videos I've watched like this one, it's hard to stay awake through some of them, but they do elicit one emotional thought, STOP TALKING AND START DOING!
Not meant towards you PolyMatrix.
PolyMatrix
No problem RunningBare.
The Lego one I am going to attempt to see if I can repeat with gears, but I only have very primitive tools to work with so have to build the Jigs and Scales and bits and pieces to aid in construction and analysis, as soon as can remove myself form this minor obsession I have with reading this site!
BTW l liked your floating magnet demo.
However I have already posted elsewhere that there is a patent verifying or acknowledging overunity only to have it dismissed as old technology! Then there is this letter from Tom Valone to NASA's chief scientist http://www.zpenergy.com/modules.php?name=News&file=print&sid=2598 where he cites substantive experiments.
The significant part of this letter is
Substantive Experiments
I should also list the following US patents as the most significant in ZPE research: "Rectifying Thermal Electric Noise" by Charles Brown #3890161, and #4704622 by Capasso, which actually acknowledge ZPE for their functional nature. Capasso is an IBM engineer and indicates that his tunnelling device only works if ZPE is present, much like what Planck discovered and Koch recently detected in the lab. I tend to recommend metal-metal nanodiodes probably will be a popular brand for ZPE usage with millipore sheet assembly. I also cite the work of Yasamoto, et. Al. (2004, Science, 304:1944) covering peptide molecular photodiodes just 1 nm across -- another example of a molecular tool for studying this zero point energy that shows up on the molecular level.
*Now to answer your question:* YES, these diodes demonstrate substantive, greater than uncertainty generation of energy from ZPE. In fact, simple coils do as well! Don't believe me? Check out the frenzy of activity that I cite concerning Puthoff's right hand man, Dr. Eric Davis, as well as Prof. Christian Beck overseas.
However it looks as though no matter what you say to a sceptic they are stubbornly still going to believe what they want to be true rather than accept that what they have learned is a slightly different viewpoint. Even today it is as K. Popper said, "It is not so much that new ways of thinking become standard it is that the proponents of the old die out"
