The Tesla Project
Started by allcanadian, January 22, 2008, 05:56:53 PM
allcanadian
Here are some neat scopeshots of a similar LC circuit, input is a single 12v impulse.
Picture 1 is a single wire from the oscilloscope attached to the (-) side of the cap, set at 10v/div- 100 microseconds.
Picture 2 is a single wire from the oscilloscope attached to the (+) side of the cap, set at 10v/div-100 microseconds.
Pictue 3 is both oscilloscope leads attached to the cap, set at 50v/div-100 microseconds.
In picture 1 and 2 we can see one waveform as it is transformed into another waveform, what I found odd is not the fact that the impulse was transformed, but the underlying frequency inherent in the oscillation. In picture 3 we see what appears to be two waveforms superimposed on one another, but it should be understood that we have two wires connected across the cap. One waveform, an inductive discharge current is incoming another waveform unlike the first is leaving. What is odd is that we are dealing with a single 12v impulse, why is a 50v waveform heading back to the source battery? Why is there an oscillating current from a single inductive discharge moving in one direction ---- into the cap. Why is this oscillation inherent in the conventional current leaving the cap for the source battery?. I don't believe they taught THIS in science class   ;D
I would like to expand on the scopeshot #3 I posted above, considering what we see and what must happen.
-- If the (+) oscilloscope probe is connected to the (+) post of a battery, the (-) probe to the (-) battery post we will see a (+) voltage on the scope above the zero boundary.
-- If we reverse the probe connections, that is (+) probe to (-) battery terminal we see a negative voltage on the scope below the zero boundary, but this is not "negative" electricity ---- only the voltage polarity has changed.
-- If we measure an alternating current we see the "sine" waveform, again there is NO "negative" electricity here the current has only changed direction, it alternates back and forth as does the polarity of the voltage.
Now concerning scopeshot #3, the inductive discharge (250+v) is alternating, we see this in scopeshot #1 and #2 as well using only 1 wire from the scope. But this is supposedly a single inductive discharge from a single 12v impulse? the inductive discharge waveform is in oscillation BEFORE it enters the capacitor, that is changing direction --- alternating, but with what?
Bessler007
What is the relationship between voltage readings (as you indicate with your o'scope pics) and magnetic fields in four dimensional time/space geometry?
Bessler007
mib HQ
http://www.bessler007.blogspot.com
Please try again. If you come back to this error screen, report the error to an administrator.
Bessler007
Quote from: Erfinder on January 23, 2008, 04:00:07 AM
The answer to this question is actually quite simple.  Unfortunately you will have to leave the path paved by conventional science if it is truly your desire to comprehend it, as the scientific community (humanity as a whole) are not prepared (yet) to accept the reality of an underlying fundamental mechanism which is beyond the reaches of the five senses.. . .
Hello Erfinder,
Your point above is so absurd I almost didn't respond but then I thought, "what the heck."  Now my suspicion is conventional science attempts to go well beyond the 5 senses in looking at (for instance) red shift to understand the expansion of the universe or at the other end using magnetic resonance imaging to "see" the structure of human anatomy to an incredible level of resolution.  There are other examples of the extension of the human senses.
What underlying fundamental mechanism are you talking about?  What do you imagine the "path paved by conventional science" to be?
Bessler007
mib HQ
ps:  don't make me sic the black helicopters on you.
Bessler007
I've been waiting all these long years holding my breath for your permission.  Thanks so much.  You have no idea how much this means to me.
Bessler007
mib HQ
edit:  At some point in time your imagination should touch down in reality.  That scientific path you suggest abandoning attempts to correlate the imagination to reality.  I wouldn't recommend abandoning it.  Since I've been given permission to think what I want, I think I'll continue to think your proposition of "leaving that paved path of conventional science" as an absurd idea.  You might try and differentiate between yourself and your ideas.  I've insulted your idea but you take it personally.
Now I'll insult you.  You are a small minded person by reason of your inability to distinguish between yourself and your ideas.  See the difference?
Enjoy your stroll into absurdity.  Drop bread crumbs so you can find your way back to reality.
Quote from: Erfinder on January 23, 2008, 05:44:07 AM
Think what you want.   ;D
Heck, since I've already dispatched the black helicopters I only feel it right to explain how you can avoid their tracking system.  You need to take two tin foil hats and a long extension cord.  Wrap one stripped bare wire around one hat clock-wise and the other end counter clock-wise on the other hat.  Now insert one hat inside the other and plug it in.
The old boys at HQ are a little frustrated with this new technique of what they jokingly refer to as the aluminum naughty.
allcanadian
@Erfinder
I have come to see many things differently in the last week, more than anything the role of capacitance. Also as you had mentioned the roles of Inductance and Capacitance as they relate to one another, there special relationship. The most exciting prospect to date however came from a most unlikely place, a 12 inch - single turn of 1/4" Diameter copper tubing as my primary coil  ;D.
When I see this in action I understand the absolute genius in teslas coil, and nobody seems to have a clue just how far Tesla had mastered his art of electrostatic induction or the secrets it holds.
