The Tesla Project
Started by allcanadian, January 22, 2008, 05:56:53 PM
armagdn03
Thank you for the many offers I got from many members, greatly appreciated.
I will be posting the information on a section of Erfinders website, Forgotten-genius.com and will announce on this forum when the first chapter is up
I have created the writing, and the video for it, and sent it Erfinders way for him to load.
Section one will demonstrate a simple concept, section two and three will introduce a simple device, that for all practical perposes is the heart and soul of many many OU devices.
I wish I could turn my brain off sometimes, then I could get some sleep.
sparks
@wattsup
      I once overheard a conversation between an upperclassman and a professor talking about radioactive decay of some isotope.  The upperclassmen proudly proclaimed that he had calculated the joules of energy released in the 1/2 life of this particular element.   The professor replied.  Now go and calculate the joules involved with a single 1s electron migration over the same period and report it to those assholes down the highway building the plant. (neuclear power plant).   Been hooked on trying to get some of that electron kinetic energy to run my hot water heater ever since. :)
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
wattsup
I received my 2nd pulse generator (the one that did not work) and started her up this morning and to my great surprise, it does work. The eBay seller advertised that the unit goes on overload when started, but this is normal if the buttons were pressed in a wrong setting. So he sold it as is for 50$ but it works. lol
I can now pulse up to 10mHz and up to 100 volts dc so more fun to come.
I will try my last high voltage experiments but this time I will pulse into a small electromagnet to replace the regular magnet and see if there is any difference when put close to the reed contact.
armagdn03
The first two pages of the talk are up on erfinders website www.Forgotten-Genius.com
You can find them under the Armagdn03 tab at the top, or by clicking here http://www.forgotten-genius.com/documents/pg__2_2.html
There will be a discussion bord on the page as well. Anybody wanting serious discussion can contact Erfinder or myself at forum@forgotten-genius.com
Space is limited so take advantage! Unfortunately there is not enough space for everyone.  I will be availible for serious questions on this forum as well, or PM me.
wattsup
Just to finish off my latest circuit tests, I did some alternative pulsing methods of my reed switch and have discovered some pretty interesting effects. Why am I looking for other methods......
Well although the reed and magnet works very well, the reeds don't last long. The tips get completely eaten away and then they soon after will stick or should I say weld together. Interesting also is that the magnet can be placed near the reed of stuck onto one side of the reed stems. So magnetizing the wire or placing it near the reed in open air are doing the same thing. Hmmmm.
Now I took a small coil from a relay and pulsed it with my DC generator at many frequencies and there was not even a flicker from the reed.  Then I simply put a straight DC 12 volts onto the coil and stuck it to the reed end and bingo I could again get the sparks although less then with the magnet and the reed burned out again. So pulsing is not good and straight dc is good to oscillate the reed.
Now here's the fun part.
I then took a solenoid coil that has an air core. This time I placed the reed through the coil. I then gave it straight 12 vdc and there was now pulsing at all and no voltage rise. I then tired with my pulse generator and at around the 3000-4000 hz range bingo. The reed pulsed at a steady rate  and there is no or very very little reed degradation, plus the voltage rise was very good and the battery drain was the lowest I had ever seen it. Pulsed DC into a solenoid coil with a reed contact inside seems to be a very good way to produce complete on/off pulsing without the constraints of a dioded mosfet (flyback killer) or the hassle of running an electric motor run rotary switch.
The other good thing is that the solenoid could be run by a mosfet and the reed contact would isolate the mosfet from the dangers of being inline with the whole circuit. Hmmmm again.
Now the next step is to include this into @ACs circuit and have some more fun. lol
I put up a diagram to summarize the effects.
@armagdn03
I will look forward to reading your doc on Erfs site.
