My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
icanbeatbob
Super God
Sweet.  Try warming up the block if have not done so already with gasoline and switch over to water.  Just an idea.  Keep up the excellent work!
>9000
gotoluc
Excellent ;D
you are not far off to having it run. I think SG is right, the motor would need to be at full operating temperature. How about you start it on gas and when it gets hot you use your spray bottle and spray hot water directly in the carburetor and see what it does. If it accelerates then it will work. I recommend to have a long pipe on the exhaust and wrap a copper pipe around it to have the water heated by the exhaust and turn to super heated steam and the pipe goes to the intake of the carburetor. So start on gas and once the steam kick in cut the gas feed.
Have a look at this video: http://www.youtube.com/watch?v=czoxOqZ8rxk
Also the GEET system was able to use 50% to 70% water with the gas mix but they could not go over that. However they did not modify the spark. I think if they did they could have it run 100% on water.
Have a look at this video: http://www.youtube.com/watch?v=HeWbzYxRrgI
You now have it all.
Luc
