My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
capacitor70
MUST SEE THIS VIDEO
http://www.youtube.com/watch?v=lxGeW4XXowc
FROM chris
he is operating water injector through switch. Water is injected on plsma.
I will try this soon
capacitor70
ChrisPCrunchy :
1. System is working on lawn mower but I have to build three more to make 4 cylinder car run.
2. Do you use a modified spark plug like the firestorm one?
   No This system is using carbon electrodes.
3. Yes and to render gas innert by converting the Oxygen into carbon monoxide so that
     hydrogen cannot reignite in the plasma arc due to lack of oxygen and the Hydrogen will not ignite until it is in contact with out side air.
4. It runs off the car battery. There is hign voltage pulses as well as R.F. generated by the driver circuit as well as about 5.5 K volts on the (grid circuit but only at about .39mA)
5. I use distilled water so I am sure of its consistant properties.I could use any water (Filtered) But the resistance and other properties would vary with each batch causing considerable tuning and retuning of device each time.
6. It uses plasma to disassociate the water molicules. Gases produced are not just Hydrogen and oxygen. It produces a type of Hydrocarbons, Hydrogen is not suitable for use in an internal combustion engine as it causes Hydrogen Embrittlement of hardened metals damaging engine over time.
7. What is the device your holding in your left hand? Also can you go into more detail on how you constructed the plasma injector system?
I am holding a circuit board with a switch which I press to activate a solinoid valve and release the gas. The solinoid wont activate until enough pressure is generated to prevent any air flowing back into cell. This experiment is very dangerous, It blew up shortly after these videos, so I dont want to give details or plans until it is more reliable and safe.
Carbon monoxide is highly poisonous, I think dont try this...
Steam trials on plasma plug1. Normal Steam.   2. Steam produced after plasma blast.
22vision
I wish, no this was posted by s1r9a9m9 7 hrs ago I am subscribed to a yahoo grp also trying to replicate this and s1r9a9m9 is talking on it. Here is the grp if you are intrested WaterFuel1978@yahoogroups.com you need to go to yahoo and register.
Also Cap I am getting an ignition coil today yay this flyback is posing issues. will keep ya all posted.
