My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
capacitor70
Blasted Bubler... Not exploded, see the shape, its implosion... water at the bottom tries to escape due to -ve pressure, and bottom of the bottle is cracked..
Timing modification unit is installed on 2HP engine, taking trials today
whopper1967
tishatang
nightlife
tishatang, no thats not the same one. I am tired now and I got to get a couple hours of sleep before I go back to the shop. I will look again later today. It's 5:47 am here.
Sorry guys, just bear with me and I will find it. i should have saved it but I wasn't interested at the time becuase I was to wrapped up with a magnet motor design at the time I cam across it.
rfsimoes
Hi every one!
My first post on this forum! :o
So capacitor70 and every one else, if you had farnell as a electronic suplier, what wold be your diode of choice?
I'm looking at this one from International rectifier
10ETS12PbF
10 Amps
Vrrm 1200V
http://www.irf.com/product-info/datasheets/data/10ets12pbf.pdf
One must consider the volts from the Ignition coil to set the number of diodes to arrange right?
If your 6a4 are running too hot maybe you need a bigger amp diodes with heat dissipator.
rfsimoes
