My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
rfsimoes
I didn't... ;D
So far so good...
Good white and loud sparks. :o
I did another test.
I got myself a epidermic 10ml syringe, cut the tip out and put the plug in the syringe.
The result was that no sound was emitted and just a tiny little bit of trust.
this test did not convinced me but how knows! Maybe water mist in cylinder has to expand with enough trust.
I will post the videos on youtube later.
rfsimoes
rfsimoes
Quote from: rfsimoes on July 10, 2008, 03:41:59 PM
I didn't... ;D
So far so good...
I did another test.
http://www.youtube.com/watch?v=g9Xz4p9fHWI&feature=user
http://www.youtube.com/watch?v=jfRi7RrD6bY&feature=user
rfsimoes
retrod
rfsimoes
No warm up was noticed. :o
Touch it after the test and it was metal cold.
rfsimoes
rfsimoes
I need to congratulate you capacitor70 and all of you that are working on this engine project.
I felt the need to do it because know I how hard it is to run the engine without knowing the correct timing of it.
I took of the original ignition coil because it was on a fixed position and it was a all in one pickup HV coil and generator.
My flywheel has too outside magnets so I only had to fixate my pickup coil on top of that.
Finding the timing for running the engine again on gasoline was a 4 hour challenge.
I also found out that the non resistor bosh WS5F spark plug was a litle bit too long and hit the top of the piston and closing the gap.
Put a washer in it but it was a no go.
The NGK plug that I run is as resistor so I need to find another non resistor plug to fit this engine.
Tomorow I will try to get help with the spark plug.
rfsimoes
