My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
capacitor70
@Xbox
If possible take test like this.
I have taken surface area test no effect on plasma. two electrodes with 6mm diameter surface for plasma arc.
xbox hacker
CPVC pipe with bolts as electrodes ;D ;D
You can feel the air more from over a foot away from the opening.......
capacitor70
Ionized air is air which is passed through high voltage plates, voltage multiplier circuit is used for this application, ionization of air takes very very less electrical power.
http://users.otenet.gr/~athsam/air_ionizer.htm
@Xbox
What is different in second picture why flame comes out from it ?
Are you putting air at one end ?
And in your pressure test you have not told how much pressure it shows ?
What happen if we put water on the electrodes ?
What happen if we use multiple electrodes with different gap ?
Give steam at one end of pipe and see the difference ?
Do not put your hand in front of pipe plasma makes hole in your skin, I have seen it with TV flyback transformer...
If you increase the gap you get more stronger arc at same energy level.
xbox hacker
@Cap70:
I used a dSLR...not a video camera, so the flames are hard to catch...those images are the only 2 i could get form 53 of the ones i took...LOL
NO AIR...just the air thats is the tube at the time of firing....
It does not say how much on the gauge....its just a guess, i will make a test with a compressor to make a guide to see how much the video shows...
The images are taken with water on them...with out water its just a bright blue light...i didnt really see a flame.
The bigger the gap...the bigger the effect....I didnt try multiple electrodes....
Steam didnt really do anything...i had tried that first
i kept it away about 3/4"..it is safe, i have done it before
It didnt work verywell...... But oddly enough, iwas able to "eject" the water form the tube with just DC...it seemd to make it "jump out"
xbox hacker
GAUGE DATA FROM VID:
The needle in the center of the yellow area, as in the vid is about 40 psi....the needle high point is about 50psi when the event happens..
I can not change the gauge with out destroying the tester...i already tried.......
Cap70 gave me a good idea, below is the image. With all my tests on spark plugs i have noticed that the electrode will "burn down".....so with the image below it should last LONGER! In tests it seems to arc in the same spot, when that area becomes burnt down, it should select a new area of the 360 degree electrode to arc form.....making the life is the device longer!
As always...just a thought... ;D
