My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
pablitosax
Hi Xbox...!
I suggest the following : An gasoline injector (a monopoint or multipoint fuel injector) that you can use as send the water presurized , with a water pump (gasoline fuel pump serve ?? ) .And pehrhaps also need a caudal regulator valve as an electronic fuel injection (same schematic).
The injector can receive 12 v pulses secuencially of a pulse of a ignition (as same of a electronic fuel injection).You must know the caudal of the injector (lbs/minute) , and the WIDE of 12 volt pulse will be a "richment" of gasoline .....?gasoline said?..sorry ... WATER say !!!
very confused ?..sorry ..
gettinwet
@Xbox
I am at work and have taken an old Detroit Diesel injector apart and removed the nozzle. I am working on silver soldering it into a fitting that you can screw into your jig and spray away. I am trying to get it to fit into an 1/8" pipe tap fitting to keep it small. I'll let you know how its going later on
Wet
PS If you dont have your plugs yet they should be there today.
xbox hacker
Quote from: pablitosax on August 07, 2008, 10:08:48 AM
Hi Xbox...!
I suggest the following : An gasoline injector (a monopoint or multipoint fuel injector) that you can use as send the water presurized , with a water pump (gasoline fuel pump serve ¿? ) .And pehrhaps also need a caudal regulator valve as an electronic fuel injection (same schematic).
The injector can receive 12 v pulses secuencially of a pulse of a ignition (as same of a electronic fuel injection).You must know the caudal of the injector (lbs/minute) , and the WIDE of 12 volt pulse will be a "richment" of gasoline .....¿gasoline said?..sorry ... WATER say !!!
i had thought of that...but i dont have any laying around...and i dont have the money to buy one....lol I guess i will have to wait till payday......
@gettinwet:
THANX for all your help!!!!
gettinwet
@Xbox
No problem man. Have to contribute how I can.
The Detroit nozzle didnt work. The holes in the tip are too fine. It takes over 100 psi to get water to spray out.
Plan 2. I have an old cutting torch tip I am trying right now. If I can get water to spray out with resonable pressure I'll send it to you.
This tip is going to require a 1/4 npt hole in your jig.
Wet
xbox hacker
Quote from: gettinwet on August 07, 2008, 11:55:51 AM
@Xbox
Wet
1/4" not a problem! The gauge and air inlet are 1/4".....
I wish i was still working at the machine shop i worked at...this would have been done WEEKS AGO....LOL
