My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
vlindos
about the "pressure" topic:
Here http://mb-soft.com/public2/engine.html is written that in normal internal combustion engines the pressure is arised 5 times during the explosion. So from 120 psi (at TDC) the piston driving force goes up to 500 psi. And that is for let say 2l engine, 4 stroke -> 0.5l cylinder chamber.
@cap70,xbox:
would you reveal little more details about the latest circuits that you are using (about the coil based).
what is the toroid size? does the coil needs to be toroid (i saw pictures from xbox using PVC :)? what is the capacitance of the capacitors included after the coil 2200, 3900, 7000 - nanofarads ? what is the purpose of the first spark plug and how the electricity goes through the gap, because the voltage after the inverter seems to be no more than 315 V? How ofter you successed "plasma sparks" in second?
@xbox:
I remember you'd said that you achieved pressure 160 psi from 40 psi - 4x times pressure increase. This is a good sign, isn't it? The thing is how to constant and make happens more often? what is the size of your pvc chamber?
@cap70:
about your latest invention: from the schema you'd posted it isn't clear what and where is destined, is this schema intented to fire a plasma spark at all  ;D ? how do you charge discharge the capacitors ?
thanks!
happyvalley808
@Xbox,
This is great news , i knew when i saw these plugs they were special. I hope they work in a motor.....WE WANT MORE VIDEO'S !!!!!!!!
@All,
These are "Champion" marine  plugs # L76V
Aloha,
HV
gettinwet
@ Xbox
Glad they got there!!! Can't wait to see the video!
xbox hacker
@vlindos:
The schematic is here.....
http://www.overunity.com/index.php?action=dlattach;topic=3977.0;attach=25503
The size if the toroidal does not matter, i use a linear ferrite rod! I am useing  500pF @ 6000V cap onthe primary side. Cap70 siad the primary spark gap is like a switch, and the secondary gets its HV from the inductance of the  transformer. I have many images, i dont know what one you are looking at that has PVC, but if you tell me what one i will tell you what it is....
@everyone:
I made a vid, and it is prossising now....but i FUCK UP...the camera died and i didnt know!!!!! LOL so i kept testing, then i figured it out, and started rolling again, but the data is off because the laps of time... :-\ But it still shows what i was talking about...AND THEN IT LEAKED AGAIN....LOLOLOL!!!!!!!!
I have to run to Lowes to get new PVC...
vlindos
Quote from: xbox hacker on August 08, 2008, 07:08:33 PM
Thanks for the explanation (silly me). So the new capacitors are just for the raising the switch on and the lesser capacitance lesser jaules be stolen from the HV spark. Wondering how much farads would be enough to raise switch enough to discharge the big cap.
The one that you've claimed you having 160 psi (i think no video was posted about that).
BTW you didn't mentioned how much is the current rate of successefuly "plasma sparks" per second (or period if not possible to count ;D )
Thank you again.
