My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
xbox hacker
Quote from: happyvalley808 on August 18, 2008, 07:17:07 PM
@Xbox,
I will do as the note say's........Nice lawton PWM....
HV
Thanx!!!  ;D
peteroks
yep just managed to finish a modified version of cap70 design a have got a working unit with regular plasma discharges.This design is great ,no diodes ,running off wall ac for the lv circuit ,just was a matter of getting the right combo of caps,in the right size/rating.This circuit has an ignition switch and manually controlled points setup -- Now the next step those marine plugs and a switching device for the [points] and onto a b&s motor . i would like to give cap70 a gold medal for his efforts,the key to his design is the cross over coil and the way you build it ,do a good jod and you get the big bang every time
capacitor70
Off topic
I am installing hydrogen booster on my car first task to monitor behavior and fuel consumption of engine with different conditions then modification to O2 sensor.
for monitoring fuel consumption I am making fuel injector, MAP, TPS, Engine RPM, Speed data logger,
I am making this type of system for industries first time for myself...
here is performance of starter motor at -10C with diesel engine.
peteroks
ok i have experience with hho boosters and they are good and easy to use on diesels here is good link--http://waterfuelforall.com/forum/index.php?topic=328.0  regarding your circuit i have good comments the wattage size of resistor [ bulb] on ac does matter as it controls the firing of the points /switch - less watts and miss fire - more watts = regular fire on plug -- can u tell me why you are interested in pwm and controling frequencies regarding plasma-----------p
capacitor70
Bulbs to prevent short circuit, no relation with miss fire. only difference is charging level of capacitor depend on bulb wattage.
PWM and controlling of frequency is for DC to DC converter no direct relation with plasma.
