My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
rfsimoes
Hi all,
So 23 tread pages and still no other replication. :'( Even worst! this tread seems to be dyeing.
Don't know what to think any more.....
A working model should never be messed with. It belongs to the shelf. A new working model should be made for improvements.
rfsimoes
rfsimoes
rfsimoes
Eddio
Quote from: Super God on January 23, 2008, 07:26:21 PM
Hello,
It has been awhile since I have posted on this forum.  I'm going to try to replicate s1r's water explosion engine.  For some reason it seemed to make sense to me, now I may be completely wrong and this may not work but so far NO ONE has actually used an ENGINE to try this on.  Bench tests will not work here.  So, I have a carburettor straight six chevy (I think) down at a junkyard that the junkyard owner will pull out for me for 100$, they will make sure it rolls over and fires so I won't have to worry about getting a dead engine.
The basic plan is to get this engine running on gasoline, disconnect the gas tank, start it to remove the gasoline from the carb, replace the plugs with those Direct Hits that Ironhead recommends, turn it over, and adjust the timing until it fires.  Unlike HHO, where you split the water, instead the water is being directly fed into the engine via the carb jets.
I will post pictures and (maybe) video if I can to show once and for all if this system can work! (I think it will)  If it works, maybe add some HHO to the mix and see if that helps?  Heh, but that is for much later.  Pics and videos should come once I get the engine.
Thanks for reading and I hope I can get this thing working!!
Hello I am new to this and somewhat clumsy, so if I goof up it is not intentional. We have just moved to a new location and are still living out of boxes and all my shop is still in boxes and not set up, and being so I will be somewhat slow in getting out pictures on my progress, but I will be giving some pictures from my projects at our previous location and yes it was very crowded in a one car garage, yet I sympathise with those who must work out of their home. I have dismatled spark plugs to see how I can make them into a plasma plug, I think the best way is to make a sub unit that is able to be screwed into the spark plug hole of the engine head and can accept a adapted spark plug into it. The unit must have dilled holes in it with check valves for the injection of pressurised ultrasonic water vapor, this vapor would be timmed for injection by a solinoid valve. My electronics are based on some of my experimentaion back a few years combining High voltage low amps which is gated to a low voltage high amps using capacitors and plenty of diodes in order to get the right values. I don't think that relays are the way to go, but rather using SCRs and electronically timed circuits. (Anyone out there with good timing circuit with isolators between the plugs and the pulsed current. I have some drawings I have made, but some things I am working on are in AutoCad and some others I must scan. What is the best format? is jpeg ok?. Ed.
xbox hacker
Its been a while scene my last post, i have been working on too many projects at one time..LOL and i have not had time to play Halo3. Anyway i have been working on some things and i hope to bring them to light soon!
One of which is a PWM with a automatic current limiter, LCD screen and 150 AMP continuous rated!!
I will be attending the FL show and tell on Oct 18th.... i hope to see and meet some of you their. But as expected S1r will not be their.....
Due to a problem with the vehicle that I planed to drive to the event
haveing blown the top of the engine off, ( intake busted, haeds
cracked, pistons drove down through the oil pan, fan through the
radiator, and other stuff blown off the engine.) I will not be
attending the event as planed.
OH WELLL!!
