My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
Super God
Lately I've been hearing that this system uses more power than the engine can supply back to the battery.  If this is the case, then we can simply use a variation of Thane's perepitia device to reduce the load on the test engine.  No big deal.  Input power is no longer a concern, this means we can supply any amount of power (within reason) to the plug and gather data on different voltages and currents.
>9000
wojwrobel
hello everybody
i know there is many people that want to misslead you from owes reason .... but don't gave up !!!
to run 1 cycle of 1 cylinder you need less than 1 ml of water to be explode, because its 1800 ml of vapor right? and even if the mixture is 50/50 cylinder is 800 ml so we need 400ml vapor so its  0.22 ml of water
in my opinion regular spark can easily explode 0.22 ml of water so i think we souled leave a plasma spark for a while and concentrate on the way of exploding water (small amounts 0,2 ml) with regular spark , something like meyer or pucharin did (injector)
there is a video on the youtube that shows that guy explodes water with voltage doubler
its small amounts but that's just what we need
cheers from poland
Rednekhippy
  Hello from the Wet Coast (not a mistype) of Canada.
  This is my first post ever on any forum and I hope I haven't chosen a thread that has 'died'. The work that's being done here should be kept alive and well!
  I stumbled across S1r's video while surfing the net and was hooked instantly. So I decided to look into to it a bit further. After many nights of reading till my eyes bled and meditating on the info absorbed I was struck by a VERY strong mental image. It has taken me several weeks to read this thread and others (along with links/related articles) to get caught up to speed as to what it would take to make an ICE run on water. The more I read, the more this 'vision' I had is reinforced. There has been a couple of comments along the lines of what I've been thinking but they have not been given much attention. My friends and family are getting quite sick of hearing me rant on about this so I thought I'd overcome my shyness and share my thoughts here. This topic seems to have ground to a halt so whats the harm in giving it a kick in the butt. Well...here goes nothin...
  There seems to be 2 problems with the plasma spark:
  1) The spark isn't strong enough. This "brute force" approach seems to work well for gasoline(petrol) but it's not enough to explode water. From what I've seen/read so far this method seems to be a power hog and has a tendency to eat plugs.
  2) The "event" happens too fast to be of any use.
  Being and avid believer in the K.I.S.S. principle it would make sense to slow the "event" down. How? IMO vacuum is the answer. Just look up into space. It is just one giant vacuum where plasma can be sustained indefinitely. Joseph Papp understood this and used it in his motor. Cap70 proved this too when he said the engine in his video was in need of a rebuild. Could it be that blow-by past the rings was venting pressure on the compression stroke creating negative pressure when the plasma was being fired ATDC? Someone else (can't remember who now) mentioned they could fire their motor on water with retarded timing too but only for a short while. Could the heat caused from friction (causing air to expand) as the engine warmed up be counteracting the vacuum?
  Another piece of evidence for this vacuum theory is the sound of the engines in Cap70 and S1r's videos. I've heard this before trying to start an engine with the timing too far advanced. It will preignite and counter rotate sending fuel vapor/pillar of flame out the carb. It will also suck the exhaust valve open as the piston travels backwards down the exhaust stroke, causing that funny noise. Is that why S1r claims his El Camino runs with reduced power? Cause the valve springs aren't strong enough to keep the valves closed? It would also be a good reason to explain why the oil dosen't turn grey from water contamination (ever blow a head gasket?) caused by blow-by past the rings (which is inevitable in an ICE)
  The final straw for cementing this theory into my heart and mind (making that little voice in my head say: "I told you so") is even Stan Meyer uses the vacuum principle in his patents. This little secret is not mentioned in words but it IS there.
  "A picture is worth a thousand words"
  Have (another) look at patent #5,293,857 http://www.google.com/patents?id=fPEbAAAAEBAJ&printsec=abstract&zoom=4&dq=stanley+a+meyer scroll down to fig. 3 and tell me what is fundamentally WRONG with this picture.
  Are these guys using neg. pressure+plasma to create pos. pressure near BDC?
  Sorry this post has gotten so long but this has been building up in me for quite some time and I needed to get it off my chest. I am quite broke atm and can't afford to replicate. Also my electrical skills are not up to the level needed to build the plasma circuit. I am slowing gathering the materials/knowledge needed to test this theory myself and I call upon those who are set up already to try this out.
Any feedback of any kind would be appreciated.
TYVM,
Red
sathika
Hi All,
Seems to be this thread is dying or already dead. But with this all 93 pages there are so many things to learn & information to where we need to go to find zero point energy (Free Energy). Most of the threads belong to this subject has been started around 2006 & reach to the peak by end of 2006 & mid 2007, but suddenly 90% of those threads has come to the end & most of the web pages also disappeared by now.
So if somebody or group can summarized all the succeeded Experiments in one place it will really helpful others or the new researchers who are very rarely find these days.
There are few method experimenting & still I’m confused what will be the best or what is actually correct as we can’t find any decent proofs.
1)   Water Fuel Cell â€" (HHO, Brown’s gas, H2 generators, H2 Boosters…Ect)
2)   Plasma Technology - (Plasma Spark)
3)   Joe cell â€" (Organ Energy)
4)   Proton Cell â€" (Proton Energy)
Above no 3 & 4 might be same, but some people claim this is similar but there are differences.
So appreciate Somebody can fine-tune all this information & it will be a great work (Even the info on this thread, as I can’t understand the end result or successfully completed one)
Sorry if I’m wrong, this is only my personal opinion & I’m bit of a confused due to the mismatch info can find in different article/ threads/forums.
Still looking for an updates from Cap70 / Xbox hac / Super Good.
Thanks & pls help others.
aussepom
