My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
xbox hacker
Here is another image i got from the pressure test vid...
You can see the start and the high point. It starts just over 40psi, and the high point is between 50-55psi  ;D
Cap70 we should exaimine the event in detail....i hope these images will help......
I got more to come  ;D
happyvalley808
@Xbox,
Wow!! 10-15 psi increase in pressure, just using two screws as a spark gap....
are you able to do a pressure test with a spark plug, i wonder what the pressure difference might be??
HV
Super God
Wow, just with the spark we are getting pressure increase?  Or did you have water in there?  What does this mean exactly?
>9000
xbox hacker
@HV:
It is a double edge sword...the pressure goes up, but it goes back down. quiman13 said that the HHO explodes and causes expansion, but when the HHO recombines to H2O it creates a vacuum.
@supergod:
It DID have water in it...i dont remember if the gauge moved without water...i will redo it...
capacitor70
QuoteIt is a double edge sword...the pressure goes up, but it goes back down. quiman13 said that the HHO explodes and causes expansion, but when the HHO recombines to H2O it creates a vacuum.
This is very important point, for adjusting engine timings, last night I am thinking about why two stroke engine worked with HHO and not four stroke, Stan Mayer also have this problem so he adds argon to reduce burning speed of HHO, same thing comes in my mind.
@Xbox
Adding inductor in series with capacitor helps to reduce current flow, this may reduce burning speed of flame. (in between spark plug and capacitor +ve terminal)
But it may create problem of glow discharge (cold electricity).
