My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
Super God
Hello,
It has been awhile since I have posted on this forum.  I'm going to try to replicate s1r's water explosion engine.  For some reason it seemed to make sense to me, now I may be completely wrong and this may not work but so far NO ONE has actually used an ENGINE to try this on.  Bench tests will not work here.  So, I have a carburettor straight six chevy (I think) down at a junkyard that the junkyard owner will pull out for me for 100$, they will make sure it rolls over and fires so I won't have to worry about getting a dead engine.
The basic plan is to get this engine running on gasoline, disconnect the gas tank, start it to remove the gasoline from the carb, replace the plugs with those Direct Hits that Ironhead recommends, turn it over, and adjust the timing until it fires.  Unlike HHO, where you split the water, instead the water is being directly fed into the engine via the carb jets.
I will post pictures and (maybe) video if I can to show once and for all if this system can work! (I think it will)  If it works, maybe add some HHO to the mix and see if that helps?  Heh, but that is for much later.  Pics and videos should come once I get the engine.
Thanks for reading and I hope I can get this thing working!!
>9000
HeairBear
KICK ASS! I am so into this! Looking forward to your progress!
HairBear
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
TheOne
You can also try to make your own Firestorm plug using cheap sparkplug and save some money :)
zerotensor
Here's a little anecdote:
A few years back, I was driving from Chicago to Minneapolis in a car with a failing head gasket.  Coolant was being consumed at a high rate-- basically it was leaking into the cylinders and going out the tailpipe.  I must have gone through about 15 gal. of distilled water on that trip.  Here's the thing-- I got over 45 miles per gallon of gas for the trip--  in a car that was lucky to get 20 mpg before!  Somehow, the water leaking into the engine dramatically improved its efficiency-- in fact, it was more than doubled.  I always wondered about exactly how this worked.
Super God
Heh, yeah to my knowledge I don't think anyone here has tried this system on the forum here, except maybe Ironhead, because he's like the HHO god lol.  Well, I hope to get a video of the engine this weekend so sit tight! =D  If not at least a picture or two, or five.  =D
-Brian
>9000
