Gabriel Kron and Negative Resistance
Started by argona369, January 28, 2008, 01:55:55 AM
                     bi-or dielectric medium = RF or IR/UR-wave frequency  Nantenna
                                  Thermodynamics and Brownian Movement
                                  Celsius          positive/0°/negative
                                  Fahrenheit    positive/0°/negative
                                  Kelvin            positive/0°                  zero pont/Nullpunkt
                    resistance : good/bad/no conduction/channeling
                   0° to 180°                     and                  180° to 360°  Hertzianische Schwingkreis
                                                        and                                                       http://de.wikipedia.org/wiki/Thomsonsche_Schwingungsgleichung
                                              Kelvinsche
                resistance: overcoming it ~ trans- : trans-resistor shortly transistor
                            seriell/parallel array =  f.e. n/p/n-transitor cell modul also cold "solar cell modul"
to thermionic/thermovoltaic cells =nantenna capturing = 0° Kelvin waves = THz bandgap width
                                              Infra-/Ultra Red radiation
              www.io.com (www.archive.org) Fellows Research Group defined it also as e-pump
              Joseph C- Yater in his description : cold/heat pump,amplifier,heat to electricity converter
              Alvin Marks,Lumilite:  1US$/qm production costs,10US$/qm selling price (1984)
S
  OCWL
Bob Smith
Quote from: raburgeson on August 25, 2014, 01:48:13 PM
I know this. The government told him what he was allowed to say and how to say it. This is documented, look for it. The 2 main areas censored is materials and the heavy side of the circuit. From words from his mouth the material is secret, part of the trick is to identify which materials go on the list. ( I believe iron and carbon are on this list) ( Check the years iron was phased out from 99% of all electrical apparatus manufactured.)
Another thing that was hidden was the fact that some oxides are super conductors.
There was an interesting video posted online about 7 years ago in which the poster used the end of a flame from a butane torch to blacken the end of a stainless steel tube with carbon, and demonstrated how it was functioning as a negative resistor. I haven't seen it in a long time; it may be taken down.  As far as soft iron - apparently it's not as available in North America as it once was. An Indian poster on a forum I was reading suggested that it could be ordered from India; he might've also provided a link. I don't remember.
Certain bipolar transistors connected in reverse bias without a base connection have been shown to function as negative resistors:
QuoteIt's pretty well known that "negative resistance" can be used to generate oscillations in electronic circuits.  What's not so well known is that some ordinary NPN transistors such as the 2N2222, 2N3904 and 2N4401 exhibit negative resistance when reversed biased.  Note that the base of the transistor is not used; the transistor functions as a diode. Output is taken off the emitter.
Source:  http://www.tompolk.com/inventions/455_KHz_Oscillator/455_KHz_Oscillator.html
One among many YT videos on negative resistance, using reverse bias transistors: https://www.youtube.com/watch?v=rpGOKGrcpAk
Bob
                                  Probably it would help to compare :
         Nantenna Transistor -LCR-circuit and the fusion-reactor 'torus' nano-dimensional process
                                                           and
100 000 000 °C / 30 000 000 000 000 Hz (= 30 THz) including mass/time-space-compression
                            Tera Giga Mega Kilo
                                                          1 Hz  = 1 cycle/sec = 2 pulses/sec
                  saxonic : dreissig Billionen Hertzianische Schwingungen
         anglo-saxonic: thirty     trillions   hertzian         cycles
                 saxonic: Milliarde anglo-saxonic: billion
                                   mental Potenz and Magnitude difference
                                   + FISICA basic language : small/great Latinum
                                           http://en.wikipedia.org/wiki/Joule
Multiples[edit]For additional examples, see: Orders of magnitude (energy)[/font][/size]
SI multiples for joule (J)
Submultiples
MultiplesValueSymbolNameValueSymbolName10−1 JdJdecijoule101 JdaJdecajoule10−2 JcJcentijoule102 JhJhectojoule10−3 JmJmillijoule103 JkJkilojoule10−6 JµJmicrojoule106 JMJmegajoule10−9 JnJnanojoule109 JGJgigajoule10−12 JpJpicojoule1012 JTJterajoule10−15 JfJfemtojoule1015 JPJpetajoule10−18 JaJattojoule1018 JEJexajoule10−21 JzJzeptojoule1021 JZJzettajoule10−24 JyJyoctojoule1024 JYJyottajouleCommon multiples are in bold face[/size][/color][/size][/color][/font]Nanojoule[edit]The nanojoule (nJ) is equal to one billionth (10-9) of one joule. One nanojoule is about 1/160 of the kinetic energy of a flying mosquito.[9][/size]Microjoule[edit]The microjoule (μJ) is equal to one millionth (10-6) of one joule. TheLarge Hadron Collider (LHC) is expected to produce collisions on the order of 1 microjoule (7 TeV) per particle.[/size]Millijoule[edit]The millijoule (mJ) is equal to one thousandth (10-3) of a joule.[/size]Kilojoule[edit]The kilojoule (kJ) is equal to one thousand (103) joules. Nutritional food labels in certain countries express energy in kilojoules (kJ).[/size]
One kilojoule per second (1 kilowatt) is approximately the amount of solar radiation received by one square metre of theEarth in full daylight.[10][/font][/size]Megajoule[edit]The megajoule (MJ) is equal to one million (106) joules, or approximately the kinetic energy of a one-tonne vehicle moving at 160 km/h (100 mph).[/size]
Because 1 watt times 1 second equals 1 joule, 1 kilowatt-hour is 1000 watts times 3600 seconds, or 3.6 megajoules.[/font][/size]Gigajoule[edit]The gigajoule (GJ) is equal to one billion (109) joules. 6 GJ is about the amount of potential chemical energy in a barrel of oil, when combusted.[11][/size]Terajoule[edit]The terajoule (TJ) is equal to one trillion (1012) joules. About 63 TJ of energy was released by the atomic bomb that exploded over Hiroshima.[12] The International Space Station, with a mass of approximately 450,000 kg and orbital velocity of 7.7 km/s,[13] has a kinetic energy of roughly 13 TJ.[/size]Petajoule[edit]The petajoule (PJ) is equal to one quadrillion (1015) joules. 210 PJ is equivalent to about 50 megatons of TNT. This is the amount of energy released by the Tsar Bomba, the largest man-made nuclear explosion ever.[/size]Exajoule[edit]The exajoule (EJ) is equal to one quintillion (1018) joules. The 2011 Tōhoku earthquake and tsunami in Japan had 1.41 EJ of energy according to its 9.0 on the moment magnitude scale. Energy in the United States used per year is roughly 94 EJ.[/size]Zettajoule[edit]The zettajoule (ZJ) is equal to one sextillion (1021) joules. Annual global energy consumption is approximately 0.5 ZJ.[/size]Yottajoule[edit]The yottajoule (YJ) is equal to one septillion (1024) joules. This is approximately the amount of energy required to heat the entire volume of water on Earth by 1 °C. The thermal output of the Sun is approximately 400 YJ per second.[/size]Conversions[edit]
Main article: Conversion of units of energy1 joule is equal to:[/font][/size]1×107 ergs (exactly)[/li]
[li]6.24150974×1018 eV (electronvolts)[/li]
[li]0.2390 cal (thermochemical gram calories or small calories)[/li]
[li]2.3901×10−4 kcal (thermochemical kilocalories, kilogram calories, large calories or food calories)[/li]
[li]9.4782×10−4 BTU (British thermal unit)[/li]
[li]0.7376 ft·lb (foot-pounds)[/li]
[li]23.7 ft·pdl (foot-poundals)[/li]
[li]2.7778×10−7 kilowatt-hour[/li]
[li]2.7778×10−4 watt-hour[/li]
[li]9.8692×10−3 litre-atmosphere[/li]
[li]11.1265 femtograms (mass-energy equivalence)[/li]
[li]1×10−44 foe (exactly)[/li]
[li][/font][/size]Units defined exactly in terms of the joule include:[/font][/size]1 thermochemical calorie = 4.184 J[14][/li]
[li]1 International Table calorie = 4.1868 J[15][/li]
[li]1 watt hour = 3600 J[/li]
[li]1 kilowatt hour = 3.6×106 J (or 3.6 MJ)[/li]
[li]1 watt second = 1 J[/li]
[li]1 ton TNT = 4.184 GJ[/li]
[li][/font][/size]
                                                   Isaac Asimov:
             Die exakten Geheimnisse unserer Welt Band 1 : Kosmos,Erde,Materie,Technik
                            Asimovs <New Guide to Science> ,1984,
                             Basic Books,Inc. ISBN 3-426-03921-4
               Seite 444,445,446,447 "Die kontrollierte Kernfusion"
               446: Beschreibung des Kernfusionprozesses als "perpetuum mobile" wirkend
                       bei repetierendem Teiloutput "feedback"
                        Dr.Helmut Reichelt, G.D.R. ,estate-energy-institute-chairman
                         Elektronen-/Ionengas-Kreislauf~Kernfusionsprozess
                  http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=12&ND=3&adjacent=true&locale=en_EP&FT=D&date=19840321&CC=DD&NR=208029A1&KC=A1
                                   Fusion-cell-array on a room surface description ,in saxonischer Sprache
